Can u sent a picture, or tell me how they go
SOURCE: 1996 Volkswagon Jetta Timing Belt replacement Procedure
there are 3 thing need to be fixed first the top timing belt pully should be between o.t so should be on . between o.t and secondremove the distrubuter cap it should be one mark 1 which is pointing on block and 3rd is crank shaft should adjust on 0 which you will find on the gearbox there is a green ruber cap remoce it and turn the main crank shaft u will find mark on the frywheel 0.
Thats it
SOURCE: 2001 kia sephia timing belt DOHC 1.8 T8
If your timing belt came off when the motor was running, there 2 possible scenarios:
Motors are interference (pistons hit valves if motor spins <=2 revolutions without a functioning belt/chain) or not.
1. if kia 1.8 motor is an "interference" engine ... major damage already occured, at best valve stems are bent and you have to pull the head to install new valves, at worst, a piston now has a hole in it and you get to do a full rebuild. I'm now praying for you;~).
2. if it's not an interference engine ... joy is you, you rotate the cams whichever way you want and pistons do not hit valves ... and as they say in England "Bobs your uncle" ... ask a Brit.
I'm guessing that Kia doesn't build an interference motor with a belt ... the dealer or any shop with access to a good paid automotive database can tell you if the motor is interference or not.
The standard explaination for rotating forward ... which is not necessarily clockwise, has to do with tensiong the belt and how you get the tensioner in the correct position to do its job ,,, which is to keep the timing belt from jumping teeth. Each motor can be slightly different for tensioning the belt, so you need the specific instructions for your year car with the 1.8 motor. If the manual says you need special Kia tool "XYZ" ... get it or an close equivalent, don't try to use a pair of vicegrips clamped to a screwdriver.
You need to spend $20 for a Haynes manual for your car. Now you or I might think for a minute that what they say in the haynes manual isn't the easiest way ... but then we would probably be wrong.
Having done several timing belts, engine rebuilds and general maintenance over the years ... I can tell you this sincerely ... advice from someone (haynes in your case) who has actaully done the job you are embarking on is worth more than $20 if you are doing a job that takes more than a couple of hours. The specific stepwise instructions they have will get you successfully to the place where you have a new timing belt and the motor runs right by the shortest path. And one of the biggest benefits in doing a job of any complexity, it that you have written stepwise reassembly procedure documented ... so you don't end up at step 17 in the reassembly ... just to realize you didn't do step
9 .. that now requires to take stuff apart for the second time !^%$@!
Good luck ... you'll feel great when the thing is purring again.
..ajm
SOURCE: engine timing marks for toyota landcruiser 1KZ-TE
The separated gears are turned in opposite direction to each other untill the locking holes align.
It needs abit of force to align the holes,then lock the holes with M6 bolt.
SOURCE: Timing belt. 1990 2.3 liter 4 cyl. Crankshaft
there should be a mark on the crankshaft pulley there should be a mark on the camshaft pulley and they should line up but to be sure bring the motor to tdc then line your mark up on your camshaft
SOURCE: camshaft timing mark crankshaft timing mark
Belt covers need to be on. Timing mark on crankshaft (while on compression stroke) should line up with TDC mark on cover. then Camshaft mark, needs to line up by looking through access hole of cover, and align mark on cam sprocket with pointer on inside of belt cover.
