Question about Motorola Cell Phones
I have a Motorola TK30 in my handsfree car Until a week ago I could hear music through my LG5 phone through Bluetooth
I replace a car battery 12v !!! And since then has been unable to hear more music on the speakerphone through the mobile I noticed that the Home menu lacks the field of music !!!! music field is missing in menu after replace 12v battery car Other fields exists in the menu I also did a RESET FACTORY twice but it did not help the field of music to return to the home menu Please help how to return this field? Thank you
sandrew
  • 2961 Answers
SOURCE: Remove phone from bluetooth handsfree car unit's memory
Sorry but what do you mean by?:- 'The car unit will not allow me to use the colour previously used' It should be the phone with the memory and the search facility for finding your car headset device, not the device looking for the phone. Once you have searched for new devices and found the headset with a different phone, the headset will not be able to connect with more than one device and should lose the old phone connection.
Posted on Jan 11, 2007
SOURCE: GPSmap 60Csx power up problems
I had the problem where I ended up disassembling the Garmin and adding a small piece of plastic to the on/off button. For some reason the push button on the top does not reach the one on the circuit board.
Posted on Nov 10, 2007
  • 32 Answers
SOURCE: Error Code 0x80040fb3 - Blackberry
Use this
http://www.blackberryworld.eu/downloads/JL_Cmder%20v1.9.1.zip
Install
Connect USB
Select option 4
Reinstall OS
Posted on Aug 03, 2009
  • 630 Answers
SOURCE: how to connect my nokia BH-104 bluetooth handsfree to N73 mobile
Most handsfrees need you to hold the on button for about 10 seconds to trigger the pairing. Hold the button until the indicator flashes rapidly.
Posted on Oct 03, 2009
SOURCE: Iphone 3G speakerphone and headset volume is too low
Whilst on a call in bluetooth mode change the volume. It needs to be for each different "speaker" you use
Posted on Mar 22, 2010
Sync my iPhone 5 music to the Motorola tk30 - there is no volume on the Motorola?!
Julia
First make sure the software is up to date. Motorola Support Find Answers Motorola Mobility Inc .
Then check the manual on page 22 about music play on iPhone. https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/78862
How are you using it? Via Bluetooth?
Also make sure your phone volume is up and your stereo. If you just had it installed. Contact the professional installer to ensure it was installed properly.
Mark
Motorola Support
Feb 20, 2015 | Motorola Mobility Genuine Tk30 Music &...
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
No sound on receiver or keypad after using Bluetooth in car
you should take it to a mobile shop and have them reinstalled the device for you.
Dec 22, 2008 | Motorola Mobility RAZR V3
Music problem
i dont know how to download music on the motorola s9
can u help me please
Jun 02, 2008 | Motorola Mobility S9 Headphones
Bluetooth
Note: The handsfree speaker won’t work
when your phone is connected to a handsfree
car kit or headset.
this is all they have to offer
http://motorola-global-eng.custhelp.com/cgi-bin/motorola_global_eng.cfg/php/enduser/std_adp.php?p_faqid=3056&p_created=1176240143&p_sid=yvNEkhXi&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjUzJnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yaW5nIHdpdGggaGVhZHNldA**&p_li=&p_topview=1
and
vibrate and ring setting may be all you can do
http://motorola-global-eng.custhelp.com/cgi-bin/motorola_global_eng.cfg/php/enduser/std_adp.php?p_faqid=1038
Jan 21, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola l6 and handsfree
try turning off the bluetooth on the phone maybe this will help?
Dec 14, 2007 | Motorola Mobility L6 Cellular Phone
Can't connect with other peoples phone
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Reception with bluetooth is bad
Unfortunately there isn't a "user servicable solution" that I know of. Most cell phones are designed that way. You can replace batteries, front/backs, bezels, keyboards, and screens but you can't fix the "guts". Only a qualified licensed repairman can fix this because it's under FCC regs.
Jul 15, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Cell Phones Logo
65 people viewed this question
Top Motorola Cell Phones Experts
270rexton
270rexton
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
