Question about Refrigerators
I have an Nova Cool RFU 9000 (only 4 years old) I have noticed an oniony smell coming from the fridge. The fridge is working but I had to turn it off because of the smell filling the cabin.
xMadx
  • 64 Answers
SOURCE: Bad smell coming from fridge
Is there any chance that small food particles have simply fallen into the fan and now trapped near or behind the fan ?
If this is the case, the food may be lodged in such a way that either heat given off from the fan or the fact the food may not be getting cool/frozen any longer, may have sent the food bad and is now generating the smell you describe.
I don't know of any fridge gas that smells like fish or funk as you put it, most are fairly neutral smelling or odorless to a point and certainly would not smell the way you have described.
  • Make sure the area is well ventilated ( run a pedestal fan nearby or open a window ), fridge gas can be harmful, even in small amounts ( especially if you don't know you're breathing it ), and if the smell is as bad as you say, you may very well be gasping for air.
  • Always have someone nearby when you attempt to do your own repair work of this nature, you just never know when you might need their assistance.
  • If you plan on looking into the problem yourself, firstly ensure the fridge is off, and unplugged before sticking fingers anywhere near a fan - plastic or not, i have seen 4 inch biscuit fan take the tip off an index finger of in a fraction of a second, so don't think for a minute because it's plastic, it won't bite.
  • Do not use any sharp pointed or metal objects to remove the fan or it's plastic cover, use fingers or flat blunt objects that can not puncture the lining of the fridge itself.
  • ( trust me when i say i speak from experience on this )
  • Be extra careful when removing the shroud around the fan, it should simply either click in or there maybe small coverings, covering 3-4 screws around the unit.
  • Remove the fan cover, being again extra careful of the unit itself and check around with a flashlight and perhaps even a magnifying glass.
  • If you can not find any offending objects, it is probably best to replace the fan and shroud and call the repair guy.
Posted on Feb 04, 2008
  • 8 Answers
SOURCE: 1998 volvo s70 heater smells strange and smoke fills the cabin
Your heater core is leaking. The smell and smoke is from the coolant evaporation.
Posted on Oct 17, 2008
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
Todd_pdx
  • 22 Answers
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try www.reliableparts.com
Posted on Apr 02, 2009
  • 212 Answers
SOURCE: Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Posted on Jun 24, 2009
My refrigerator has a smell that it never had almost like plastic.it is about 10 years old
the smell on your fridge sounds to me like its leaking.inside your fridge is surrounded by a type of gas that helps to keep your foods cool.once the side walls of the fridge have been penatrated the gas leaks out. in my experiance the unit is unreparable and fit for the bin
Apr 23, 2011 | Maytag Refrigerators
SAAB 9000 CSE 1996 - Coolant likage
With the vapor coming out I would say you have a hole in one of the heater hoses which go into the firewall in the area you describe. Inspect the hoses looking for the vapor with the engine still hot.
It could also be a leak in the heater core. The vent the vapor came out of is the source for fresh air for the heater and a/c. You should be able to smell antifreeze with the heater on inside the car if the leak is there. Water may also drip on the passenger side floor from the heater core.
Jul 26, 2010 | 1996 Saab 9000
My refrigerator and freezer have slowly stopped cooling. Now I am noticing an oily smell when I come into the room. This refrigerator is 26 years old and has never needed repairs so I can't complain. Could...
The oily smell is a indication that your Fridge has develop a leak and is in need of specialist attention/repairs. The technician needs to determine where the leak is - if it is repairable because sometime with a old unit your repair the one leak and it develops another. Charging it with new refrigerant with the the repairs is just a short term solution. There must be appliances repair technicians in your area that will give you a quote!
Pine
http://www.vintageelectricappliances.com
Jun 06, 2009 | Refrigerators
Apr 01, 2009 | Refrigerators
Amana side-by-side fridge freezer only cold at the bottom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Frigidaire PLHS267ZA Side by Side
Did you leave the door open? check the light socket for shorts ..check the door switch the light will go off when to door is closed..
May 04, 2008 | Frigidaire PLHS267ZA Side by Side...
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
