Question about Sony Televison & Video
Need help repairing a Sony TV XBR65X900C that was hit by lightning. Has no video or audio
Have replaced main power supply and main video boards. With room dark there is light in the background of the screen. What boards should be replaced now? T-Con?
  • 1153 Answers
SOURCE: No audio, no video
Can you find out what Led is not on or which comes up and goes out? Most of these sets have convergence problems. Or Power Regulators.
Posted on Sep 23, 2007
SOURCE: I have a Samsung LNT4665FX with screen problems. I
To solve this type of problem, you need a piece of white chalk. Draw a line around the area where the set is at. Call a priest - and lay the poor thing to rest!!!! This isn't the first time Samsung has "dropped" junk onto its' customers. Their dvd players also had problems with their DSP I.C.s that would over heat and cause the video playbacks to "break up". Don't waste any more time or money on the product!!!!!
Posted on May 18, 2010
  • 8457 Answers
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Posted on Jun 22, 2010
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Posted on Feb 07, 2011
SuperTech-11
  • 1591 Answers
SOURCE: I have a sony kdl-46s2000
If it's not the t-con board, There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both - but in your case, most likely the power supply.
Any caps in these (or any) sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Jun 04, 2011
What's the likelihood of my TV being able to be fixed after a lightning strike killed all electronics on one wall?
Probable power supply fault now. Maybe if you replaced the power board it might work again.
Jun 19, 2017 | Vizio Televison & Video
TV no power.Cable hit by lightning.
if didnt have a surge protector and unit took a lightning hit more than likely unit totally fried
Jul 31, 2016 | Televison & Video
E321vl no power. could this mean bad logic board?
The downside of a product getting a power surge is it will never be just right. It is not worth the cost to repair it. Consider buying a new TV instead. Suggest a Smart TV.
Mar 24, 2015 | Vizio Power Supply Input Main Board Unit...
Lingthing hit my tv and the power don't come on.what o I have to replace
Almost always, the power supply board will need to be replaced after a lightning hit. If the cable or antenna input was hit, you will need to replace the main board also. It is usually cheaper to replace the TV than to repair a lightning hit.
Sep 23, 2014 | Sanyo Televison & Video
Dynex tv
If your TV dead after the lightning, then your TV doesn't power ON with red light stays on lit you possibly have faulty main board.
If totally no indicator try to replace the fuse on power supply board if busted or blown (it is usually connected directly from power cord.
If the fuse still blown you need to replace the whole power supply board.
please rate!!!
Dec 05, 2012 | Dynex 32 in. LCD Flat-Panel HDTV
It was blown by the lighitining
There is nothing much that can be done if the board has been cooked. sorry you might need a new board or set as according to cost..
Oct 11, 2010 | Sony STR-DE497 Receiver
2007 Sony Trinitron WEGA will not turn on (no nioses, nothing)
right if it has been struck by lightning then a wide array of components will be shorted in the powersupply from diodes to capacitors, resistors and driver IC's , the fuse and Mains Transformer and all will need to be tested individualy but if they look black and charred then they need to be replaced.
Nov 05, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Lightning Strike, Plz Help!
Hi. The red line on ICS is quite normal it does not mean the part has failed. To be honest in most cases if a tv has been hit by strike it is a right off & scapped. What I suggest is to remove the main pcb & power supply pcb if its seperate & inspect the print side of pcb for signs of arcing tracking or burnt track. Repair any damaged track by cleaning off the coating to get at clean copper then solder wire accros to bridge the damage. Check the power supply resistors diodes transistors look carefully for any burnt components or components which are physicaly damaged. Check the line output transistor this will be near the large transformer with a thick red ht lead going up to the crt. Check all the components you can in the line stage look at all the ICS to ensure none of them have holes in them or have blown apart. Hopefully you find some or one if your very lucky that is damaged replace it & try your tv.
Sep 23, 2007 | Toshiba CZ36V61 TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
