Charging stand for doro626 phone
How to purchase
I have a Doro626; how do I turn the speakerphone on? Thank you
Try Googling (doro)(626)(manual) without parens to get instructions.
Aug 03, 2017 | Cell Phones
How to charge new battery
One you have replaced the batteries, place the unit in its charging stand and it will inform you approx. how long until the charge is complete. If not, there will be a charging status bar at the top right hand corner. I would typically leave it on the stand for 12 hours minimum. Also, do not put it back on the stand until it tells you that charging is required. Putting a device on charge before required develops a "battery memory", meaning the battery may be half full, but read as empty requiring a full charge.
Oct 09, 2015 | Uniden DECT 6.0 Cordless Phone
Does the arcitec 1050cc come with a seperate charging stand as well as the jet clean device?
Originally, all Arcitec models came with a simple charging stand. That part is no longer available. If you need a simple charging method for your shaver, there is a charging/travel pod. It can be purchased at shaveroutlet.com at the link below
http://shaveroutlet.com/philips-norelco-arcitec-power-pod.html
Feb 12, 2015 | Philips Norelco arcitec 1050CC Electric...
My phone are not keeping charge
Either you need to replace the rechargable batteries or the contacts on the charger are not touching the contacts on the phone. As the battery gets old they do not keep as charge as well and will eventually not charge up.
If the battery is good and the phone is properly seated in the charging stand then most likely a wire in the charging stand has come loose from the charging stand contacts inside the phone somewhere. Have someone who knows what they are doing fix it (solder the wire back on to the contact)
Lastly, the phone or charging circuit could just be dead...zapped by lightning or static discharge from owner when they pick it up to answer it.
Oct 22, 2013 | Uniden Cordless Phone
I hv nokia7210 phone after 1.5 years suddenly the charge not stand . i change the battery even though the charge not stand beyond 3 hours. some unknown icon "G","E" are appered in top of the screen near...
Symbol "G" and "E" are not related to this problem."G" means GPRS and "E" means Internet .The charging problem might comes due to bad charger or cgharging coil might fused or charging filter (IC) might sort.
Aug 15, 2010 | Nokia 7210
Not charging in nokia1600
That means that either your mobile contains the wrong battery, try to purchase the exact battery for your phone or else you could purchase the right charger for it.
May 19, 2009 | Nokia 1600 Cellular Phone
Charging receptical has broken off inside the phone
you both will need to take the phones in to a mobile service center and have them replaced the charging ports.
Feb 25, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Beeping Handsets
Mine have done that as well.
After cleaning the contacts on both the handheld unit and the base itself, it seems to stop the problem. Try using a qtip that is wet with water or alcohol.
Oct 10, 2007 | Siemens Gigaset 8825 Cordless Phone
Handset gets warm on charging stand
The handset and the AC adapter can become warm. This is normal operation on this unit. If it is too hot to touch, your unit is need of repair.
Dec 03, 2005 | Vtech IP5821 Cordless Phone
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
