Question about Samsung RS265LABP Side by Side Refrigerator
SAMSUNG RS267LAPB The freezer is fine , the fan is running but i can hear it hitting ice so i took the panel off and defrosted the coils and it froze up with in 2 weeks
    Scholar:
  • 117 Answers
You have a defrost component failure. Either the defrost thermostat or defrost heater most likely. Bypass the defrost therm and place into defrost by turning defrost timer clockwise until you hear a loud click. if heater comes on then defrost therm is bad .If heater does not come on then it is a bad heater. you can check continuity with a ohm meter Hope this helps
Posted on Jul 28, 2009
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
Dec 27, 2015 | GE Refrigerators
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
I have a top-mount Frigidaire Gallery frost-free freezer, and everything in the freezer and the freezer interior is covered with ice crystals. Suggestions?
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 24, 2009 | Frigidaire FRT15B3A Top Freezer...
Freezer working: refrigerator not cooling
Sep 23, 2009 | Frigidaire GLRT83TES Top Freezer...
My Whirlpool upright freezer keeps building up ice inside the bottom back wall. The fan starts rattling and freezer will not stay cold enough to make ice. If I take everything all out and leave it off...
Either your defrost timer, defrost heater or defrost thermostat has failed. All parts are located behind the lower back panel inside the freezer. Most likely are the defrost heater and defrost thermostat.
Jun 09, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Freezer way too cold - ice cream hard as a rock
The freezer may get as low as -18 degrees F or 0 F this is the point when life and bacteria stops growing.
Ice cream shouldn't be that cold unless it is whipped with air.
Feb 27, 2017 | Kenmore Refrigerators
Ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Dec 16, 2008 | Frigidaire Refrigerators
Kenmore Refrigerator Freezing Up - Won't Defrost
i have a side by side kenmore frig freezer on th frig side the pop is freezing up and the water that comes out the door whtat could be wrong
Oct 12, 2008 | Refrigerators
Samsung RS265LABP Side by Side Refrigerator Logo
407 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
