Question about Roku Televison & Video
I moved and I'm having trouble setting up my roku
How Do I Remove Or Add Channel On My Roku?
You have to use your computer to connect the roku device to your TV. You have to sign into the roku site, navigate to new device. You then plug in and fire up your roku. It will give you instuctions on the tv screen with a code you enter into the site to sync your device . Once you do that you can use the store on the tv to install channels or you can use the computer with a code to send channels to the roku on your Tv..
Dec 12, 2017 | Roku Televison & Video
Tip
Roku, How To Setup a Roku Player
You want to try the Roku player so you can stream NetFlix to your TV over your home internet connection. It can be a bit of a hair pulling experience to set one up. So I'll try and make it as easy as it can be. First; Once you receive your player, and connect it to your TV. You need to get your new player on to your home network, be sure you have a router with wireless capability's. You will need to know the name of your home network, and you will need to know your WEB key or the pass key to secure your access into your home network. To do this, go to "Settings" (on the Roku menu) then scroll thru the menu until you see "Network", press network, look for your home network and press on it, then put in the WEB key to access your home network router. Remember after each step unplug the Roku for 10 to 20 seconds to set the memory.(may take more than 1 time with some players) NEXT; Go to www.Roku.com internet site and set up your account with them, they will need info on how to bill you if, you use a pay chanel. So they will need some bank account info, Or you can use PayPal. Next On the Roku "My Account" page, down at the right bottom of the page you will see the "Link Player" button, follow this to input your Link code, or go to http://owner.roku.com/link to input the code. Then go to the Roku menu screen and finish the setup with your Link Code. This will now activate your new Roku player. Next you will want to go to NetFlix and set up an account with them. Same thing here, they need bank account info to bill you, if you stay past the free demo time limit. Now go back to your TV, Roku menu and scroll thru the menu to press on NetFlix, here you will go thru the Menu to get another link code. This time it will come on the TV, Roku menu to go back and put that code in your NetFlix account to activate your Roku player with NetFlix. Now in the process of all this, you may have to unplug your Roku player after each link code to set it into memory. This causes a lot of folks to have some trouble as they do not, "Turn Off" the Roku after they put in the network key, the Roku link code, then again after they put in the NetFlix link code. One last bit of help. Do not create a large Instant Queue on your NetFlix account over 50. This causes problems with the memory usage in the Roku player, and It can keep NetFlix from loading. Hope this helps FixYa up.
on Jul 31, 2011 | Audio Players & Recorders
I want to install my new Roku.
Basic and Easy Steps for Roku Installation:
Roku brings you to enter the entertainment world with the simple and easy steps. Before doing anything on your Roku, first, you need to set the Roku to your TV. Follow the given steps one by one for setting up the Roku.
aid4936481-v4-728px-install-a-roku-3-step-5-version-4-2khk00yt5o2tmntvewusvmgu-3-0.png
Step 1: Unpack your new Roku from the box.
Step 2: connect the Roku to your TV through the HDMI cable.
Step 3: power on both TV and Roku player.
Step 4: After turned on, the first screen will be the language settings.
Step 5: Here, Select the language from the list. Connect the Roku to your Network:
In this step, you can connect your Roku through the wired or wireless connection. If you're using wired connection means, connect the Roku with LAN or telephone wires.
In Wireless connection, follow the given steps.
Step 6: Go to the Roku Settings and select the "wireless" option.
Step 7: Select "Set up new wireless connection" and select your network from the list.
Step 8: Enter your network password, if required.
Set the display type:
The Roku will automatically set the display resolution or else you can also set your resolution.
Step 9: Select "Set display type" option and press "ok".
Step 10: After that, the screen will go blank for a few seconds.
Step 11: Enter the Roku code link that shows on your TV screen in Roku account creation site.
Step 12: Fill out your information for completing account creation.
Step 13: Now your Roku gets activated and add your favorite channels to your account.
If you need any information about Roku Activation Code, call us at 1-844-965-4357.
Oct 07, 2016 | Roku Streaming Stick
How do i login on my tv using the roku device that was previosuly working fine.
If your Roku is plugged in, your t.v. has also have to be set to the Roku player select button or a different channel. Either, DTV or something similar. Then it will show up with the Roku Icon and then it takes a few minutes to come on.
Feb 12, 2015 | Roku XD Streaming Player 1080P Wireless-N...
Since we have moved am having trouble
Check your router logon and password if you are using wireless, if you are at a new address chances are it is different. If you're using a wired connection make sure it's set to wired.
Jan 30, 2015 | Roku Televison & Video
Roku will not find my network
Try moving your Roku closer to your wireless router for a better signal.( Try scanning for networks again with your Roku, through the wireless settings window) If your wireless router is set to hidden mode, you will need to login to your router, and temporarily change it's mode to visible while connecting your Roku device. Once you've connected successfully, you can change the router back to hidden mode.
Nov 28, 2014 | Roku 2 XD Streaming Player 1080p (3050R
Roku.com/link
Once your device is set up, visit the link http://www.roku.com/link from a PC or Mac to enter the code.
You can't do it from the roku device itself.
If you are still having trouble, visit http://support.roku.com/entries/244199-how-do-i-set-up-my-roku-player
to get the walk-through on setting up your player.
Dec 10, 2011 | Roku XD Streaming Player 1080P Wireless-N...
Not sure if router is sending signal to roku
Go to the settings menu, then Network, If the Roku sees your network all you have to do is put in the WEP key to connect to your home wireless network. If the Roku does not see your home network try moving the router or the Roku away from any heavy metal in the room, (ie fireplace, or objects). Hope this helps FixYa up.
May 23, 2011 | Belkin F5D9231-4 Router
ROKU can't connect to local area network.
Have you got past the point where the Roku updates itself? If not, connect the Roku to the router via ethernet to get to that point. Make sure you can watch something on the Roku. Then try connecting wirelessly.
2. If you are still having trouble, connect the Roku directly to the modem. (this is temporary). If you can get the Roku to work, the problem is with your router and not the Roku.
3. Restore all the connections - it would be a good idea to reboot everything: Let the modem come back up, then the router, then the Roku.
4. Check for firmware updates for your router.
5. If you are still having trouble, post the make and model number of your router.
Feb 05, 2011 | Roku HD Player (N1100)
Televison & Video Logo
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
