Question about Motorola Televison & Video
My T7510 Motorola Talkabouts won't emit/receive with one another.
It only works if they're both set on SCAN and I press hold until they find each other. Oddly, they stop scanning and aren't even on the same channel. If I don't talk for a few seconds, they both go back to scan.
Benimur
  • 6966 Answers
SOURCE: i have a problem
Normally in a Motorola T5700, to set a specific channel to monitor (and reply to) called your working channel, you press the Menu (center) button and the current channel shown in the display will flash. Press either the + or - buttons to change to your desired channel number which should be identical to both radios. Press the PTT button to save.
Likewise, both radios must have identical Interference Eliminator Code. To set code, press Menu till the code display blinks. Press + or - to select code. Press the PTT to save. To disable the code, select 0.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 22, 2008
SOURCE: SVC Scanning
Reset scanner by powering off, press the Hold,2 and 9 keys all at the same time and turn on the scanner.
Posted on Jan 01, 2009
eradiostore
  • 1654 Answers
SOURCE: channel will not set just continues to scan.
Your radio is in scan mode. You can shut off scan by referring to page 8 in the user guide http://www.giantintl.com/ContentManage/manuals/Moto/T4500_User_Manual_E.pdf
Posted on Jul 16, 2009
SOURCE: Pro-164 scanner stops receiving when Motorola talk-ids are progra
I had to buy the Radio Shack USB cable 20-047 and install
the driver for it and then I downloaded a program named
"Win97" from the www.starrsoft.com website as listed
on page 21 of the Pro-164 manual. The cable costs
$34.99 and with tax you are looking at about $37.88.
The "Win97" software must be registered for it to work
after a 30-day free trial period. That's approx $25.00.
This is the ONLY WAY to go !! You put in everything
on the software GUI and then upload it to the PRO-164.
Works like a champ !!!!!!
Posted on Jan 01, 2010
  • 123 Answers
SOURCE: second hand pixma mp210 wont scan, no ink does that matter?
try shaking the ink cartridge then reinstall it again canon pixma ink
Posted on Jan 14, 2012
Talkabout T461. Transmits, but why doesn't it receive?
Blown speaker is possible, but not likely. It is almost always the programming. Check that first. I would take the non listening radio and press and hold the scan button down until you get the squelch noise, about 3 seconds. Continue holding it and use the other radio to "talk" to it. If you hear the other radio, it is likely the programming is off. These are nice radios, but easy to bump onto the wrong channel or even setting. Oh! Remove all audio earpieces before trying this.
Jan 25, 2016 | Motorola Radio Communications
I would like to change the frequency on my XU2100 to frequency #6 so that it receives tran smissions from our other 2-way in our community watch. If we leave them on scan they do work, but we would like to...
Hold the PTT button and the MON button in while turning on the radio. Continue to hold them until the programming initialization noises stop. Press the menu button one time to get to the Freq setting, change it to 6. Then press the menu button to lock in this setting. The next menu screen is the Code, set it to match your other units. Then press the menu button again to lock it in. Press the menu button to walk through another 2 or 3 screens and then you will hear a different chirp. Your radio is now programmed, simply shut it off and turn it back on and your radios should work.
Best regards.
Jul 22, 2011 | Motorola XU2100 (1 Channel) 2-Way Radio
Walkie talkies model gmr325-2 ic;513C-UT914 HOW DO I GET THESE TO TRANSMIT, MY HUSBAND HAS CANCER AND WE NEED THEM IN OUR BEDROOMS AND WHEN I AM OUTSIDE, TK U, TK U
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
KEYLOCK ON/OFF
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
ROGER BEEP
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
I have old motorola talkabouts..and don't remember to change the channel. can you help? They are Yellow and have no screen on them...I can't find any model number on them. the date is Dec 1998 it...
Hold the push to talk(PTT) button while turning the unit on, it will talk to you. press PTT to change channel, push monitor to switch to codes, press PTT to change codes. When you have the correct settings press monitor and it will confirm settings.
Jun 13, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
Set clock jvc car stereo do not have manual need to know how to set clock
Press and hold SEL until menu appears
Using the scan button (FWD/REV), select Clock H
Using the volume knob/button, set the value
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
May 09, 2010 | JVC Car CD Receiver With Detachable Face...
118575 remote stopped working batteries are new lights light up but wont control tv or satellite anymore even though it just worked
The receiver more than likely received a software update or reset itself and reset the codes to the receiver and tv. We will need to set the remote address again and run a power scan to control the tv. Using the front panel buttons on the receiver press the menu button twice. This will put you at the system info screen. You will see the remote addresses for tv 1 and 2. They will probably both be set to 1 if the receiver reset. Press and hold the SAT button on the TV1 remote until all lights across the top light up and release. Now key in a two digit number between 1 and 16 (for 1-9 precede that numeric with a zero) now press the pound key at the bottom right of the remote numeric keypad. The SAT button will flash three times and press the record button until the remote address on the screen displays the one you entered. The receiver should now be able to be controlled by the remote. Now we need to do a power scan - press and hold the upper left TV button until all buttons across the top light up and release. Press the red TV button and release, The TV button should be lit constantly. Now press the channel up button slowly until the TV turns off. Once it does press the channel down once and then cannel up to see if the TV turns back on. If it does press the pound sign. Now press the record button and you are back in business. If you have further issues let me know. Thanks for using Fix Ya.
Apr 03, 2009 | DISH Network IR Remote Control
I need remote control code number for motorola dvr 6416 III
If this is a remote by UEI or Atlas (usually the black remote that the cable company supplys with the box) the code is 1376.
To set the code, you will need to do the following:
Unlock the Cbl button:
Press CBL once. it will blink once.
Press and hold SETUP until CBL blinks twice. Release setup
Press 982
CBL will blink 4 times, indicating it is unlocked
Program the code in:
Press 1376
CBL will blink twice if the code is accepted.
Re-lock the CBL button:
Press 982
CBL will blink 2 times, indicating it is locked again
If it is not a UEI or Atlas remote, let me know the remote make and model
Dec 01, 2008 | Arris DCT6200 DTV Receiver
I have a problem
Jan 22, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Neither radio will receive or send
Motorola Talkabouts usually a have a CODE you can set for each channel. This is like a TPL / DPL code. If its not set the same for both radios then other radio may not receive.
GP300. Assuming they are programmed to talk to each other, ie RX and TX of each on the same frequency or they may talk through a repeater and that the TP/ DPL code are correct. If you have the Speaker icon crossed through they are probably muted, but in this case you should be able to unmute them from the keypad. Only other thing is if they are programmed for Selective Call, then they would only unmute on a call which contains their ID #. There several Selective call systems, MDC, Select V , Quick call are just some. Europe usually opts for a certain type of Select V. US uses MDC.
Nov 24, 2007 | Motorola Eliminators: GP300 Battery...
The radio probably needs reprogrammed to match the other units. Check your owners manual for instructions.
Oct 18, 2007 | Motorola Talkabout FR50 (14 Channels)...
Televison & Video Logo
27 people viewed this question
Top Motorola Televison & Video Experts
Jaime Hernandez
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
