Question about Garden
My Yard Machine riding mower seams to be stuck in gear? Will not move forward or backwards in neutral. The engine cranks well and starts to fire but immediately dies. Im thinking its stuck in gear?
  • 33 Answers
SOURCE: husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
Posted on May 02, 2009
libaredneck
  • 119 Answers
SOURCE: MTD RIDING MOWER with 618-0229 transmission.
sounds like you need a new drive belt
Posted on May 04, 2009
  • 130 Answers
SOURCE: Poulan Riding Mower will run in neutral, not in forward or revers
you have safty switch on the mower one or more are bad there are three of them
win you put in reverse some mower will cut off this is a safty device on some mower
Posted on Jul 18, 2009
SOURCE: Murray Riding Lawn Mower won't start or move
The Drive Belt keeps coming off as soon as I engage the mower I replaced the Drive Pulley and put on a new belt but it still comes off. Any Ideas.
Posted on Aug 15, 2009
SOURCE: Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Posted on Sep 03, 2009
My john Deere 100 series .... Gear stuck in reverse.... And will not start because it is stuck in reverse!
sit on the mower and push the clutch in
start moving the mower by rocking it forward and backward while trying to put it in neutral,don't worry about your neighbors thinking their is something wrong with you while you are doing this.
Oct 10, 2014 | John Deere Garden
Stuck in gear
I'd go to the junction of the linkage and the transmission and check from there. The transmission will have a lever or some sort of protrusion connecting to the linkage. See if you can move the lever/protrusion by hand, even if you have to disconnect it from the linkage. If you can move it, try to find neutral and reattach the linkage and adjust it so it corrresponds to the indicator on the shifter. If you can't move the lever/protrusion it's internal to the transmission and you are out of luck unless you're up to cracking open the transmission.
May 10, 2014 | Yard Machines 155 Torque Briggs Stratton...
My Weedeater riding lawn mower will not move when it is in drive or reverse
Check your drive belt that it has not slipped off the drive cog under the motor. Also check the alignment of the motor with the handle on the right side (speed, reverse, and neutral lever).. This lever tilts the engine to engage the drive belt.. there is no transmission in this machine.. just how the belt engages by its angle when you push the lever forward and backward.. If the engine is running, it must be either the belt to drive the unit or the angle has been messed up somehow..
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
Craftsman lt1000 rider 42 in deck is stuck in gear and wont go into neutral. so i cant get it started.
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mower will run will not go foreward or backward
With transmission in neutral...start the engine and move the speed lever to highest speed and move it back to brake position, then shift the transmission into gear and move speed lever, this will fix the problem.
Apr 26, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
