Question about Electrical Supplies
I have an outlet that only has three black coated wired coming out of it. Two hot and one not. It had a light switch connected to it and down the line GFI plug in. Not sure how to reconnect with that?
    New Friend:
  • 18 Answers
A little more detail please, I don't understand what you're trying to do
Posted on Aug 28, 2017
SOURCE: Hampton bay Windward III
Green and copper are the ground wires and I believe you can connect both these to the green wire from the fan (I only have the copper wire in the actual ceiling box). Black and Red can be treated as both black and both can be connected to the black wire from the fan (this is what I did in all my fans and it worked). White is the neutral wire and can be connected to the white wire from the fan (this is what I did in all my fans and it worked).
My ceiling box has the copper, red, black, and white wires. The ceiling plate for the fan I bought had a green wire. I connected the green wire from the ceiling plate and the copper wire from the ceiling box to the green wire from the fan.
Posted on May 22, 2008
  • 19 Answers
SOURCE: Connecting Leviton Decora light switch.
At the switch you have a feed wire coming in this brings in power which originates in the electric panel. You also have a feed or feeds goings out to other lts or switches, this you seem to have on the switch. instead of the closet switch loop.undo all the wires. find the only hot this is the one wire you can touch to the others and make different lts come on i reccomend getting a electric tester to do this. FInd the wire that goes to the closet lt. Once your sure put it to the side. wirenut all other wires together with the hot wire. this makes all other switches independantly hot. connect the hot to the switch and the closet lt to switch. I HOPE THIS MAKES SOME SENSE TO YOU . let me know if i can help
Posted on Jan 04, 2009
  • 3433 Answers
SOURCE: GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
Use a two pole GFCI circuit breaker on such circuits.
Posted on May 20, 2009
SOURCE: when radio is plugged in only the gfi outlets work not the radio.
Mines similar, outlets work but radio will only work on battery. Radio will not work on mains only. Charger works at same time so ok. SORTED IT TONIGHT. Inside the charger inside the box there is a fuse (240v 2A) I think, tiny radio fuse. Changed that tonight and radio now works on mains only or battery. Very awkwark job but better than watching a load of cr** on tv. Hope this helps someone.
Posted on Aug 18, 2009
  • 12744 Answers
SOURCE: I'm using a Leviton 1755 combo 3 switch for a bath
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Posted on Feb 22, 2010
Light switch wiring
The code is maximum 12 boxes per circuit breaker.
You can connect a 12-2 NM W/G cable to one of the outlets. Black-to-black and white-to-white and ground-to-ground. Black is hot, white is neutral, and ground is ground. And bring that cable into a hollow-wall box you install 50" high on the wall. Then run the 12-2 cable up to your light fixture.
You can also replace one of the outlets with a combo switch-outlet. The run singe 12-2 cable up to light.
This wiring diagram shows half way down how-to-wire-switches page.
Outlets have wide blade on neutral side, and narrow blade on hot side.
The black hot wires from old outlet connect to side of combo device with narrow blade.
The white neutrals from old outlet, and new wire going to switch, all connect to silver screw on wide-blade side of new combo device.
The black wire going to new light connects to screw next to switch located on wide-blade side of device.
Aug 28, 2012 | Electrical Supplies
I have a light switch in my apartment that controls both the light in the kitchen and power to both sockets of a dual outlet. How do I adjust the wiring so that the outlet is always powered? The wiring...
This is not good wiring option. It is not good to have light and outlet on the same switch without different fuse. I suggest to insert another little switch on light connection. Than you can have control of both. Or you must find main phase (hot wire) inside switch box. This will be always on for tester when you try different switch position. When you find this main (hot) wire, you disconnect one of another two wire (after you disconnect power), than give power on and test light and socket (one of them will not work). If this is outlet, you must connect this wire to main (hot) one. Don't work when power on. Just test it with tester, and than disconnect when you change position of wire.
Good luck and be careful!
Aug 26, 2011 | Electrical Supplies
I have the 691tr-icc6 outlet/toggle. I would like the switch to control the outlet below it. So I can turn on and off the outlet as needed. , Where do I put the black and white wires that come to the...
You have switch plug combo with dark screws, brass screw, and silver screw.
Dark screws are for black Hot wire coming from breaker box.
Brass screw is wire going to Load that you want to turn on-off.
Silver screw is for white Neutral wire coming from breaker box.
To set up so switch controls outlet, you need 2 dark screws on one side of device that are connected by break-away fin.
Remove fin so dark screws are no longer connected.
One dark screw goes to switch, one dark screw to outlet.
Hot black wire connects to dark screw for switch.
Connect jumper wire from brass Load screw to the dark screw for outlet.
Connect Neutral wire to silver screw.
To test for Hot and Neutral:
Separate wires.
Turn power ON.
Test each wire to bare ground wire, tester lights up on Hot.
Hot is identified.
Test Hot wire to all other wires except bare ground, tester lights up on Neutral.
Mar 28, 2011 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
I have three wires, two are black and one is white. I want to have the outlet active and the switch control an overhead light. How do I connect the wires?
Connect the white on the switch to the white in your house, one black to the hot coming in, and the other black to the hot wire to the overhead fixture.
Mar 13, 2011 | Leviton Decora Combination Switch - 5625-I...
I bought a leviton combination two switches. I would like one to go to a recepticle, that i can switch on & off. The other switch i would like to go to an overhead light. Any information will be...
The wiring for the overhead light is the same as for the outlet. I don't know what wires you have in the box where you will be putting this switch, but I will assume the simplest case. The box should have 3 sets of wires. Each set has a white, a black and a ground. One set is hot, coming from the main panel. One set goes to the light. The third set goes to the outlet. Connect all three ground wires together and to the ground lug on the switch. Connect all three white wires together, but not to the switch. Your switch will have 4 terminal screws. On one side of the switch, two of the screws should be connected together with a little metal bar. Connect the hot black wire from the panel to one of the two screws that are connected together. (the other screw is not used). Connect your black wire for the light to one of the screws on the other side of the switch. Connect your black wire for the outlet to the last remaining screw. Be safe. good luck. Let me know if you found this helpful. Al K
Jan 19, 2011 | Leviton Electrical Supplies
I just bought a switch to control both fan speed and light control (dual switch) i hooked it up every thing worked fine. then to realize that the outlets that follow dont work. just as a clue on the...
The key seems to be that you changed wiring in the ceiling box.
I suggest you make a drawing of the wires before and after. Track the route that the Hot wire takes.
The key question is this: Does Hot wire from breaker box arrive in the ceiling box first? Or does it arrive in wall box first?
I think Hot from breaker arrives in wall box first. And from there Hot wire goes to ceiling box ... and from ceiling box the hot wire goes to other plugs in room. If this is true, you will be one wire short for installing fan control switch.
I always make a drawing of existing wires before starting, so I can put it back the way it was. It sounds like you got a good handle on which wire goes where.
We used to solve the one-wire-short problem by making a simple project bigger. Figure out which direction ceiling joist run. See if you can slide fish line from fan ceiling box over to wall. If that works. Over at the wall, chop small hole in ceiling so you can feed wire up to fish line. Pull wire over to ceiling box. Next, staple other end of wire along ceiling over to location above wall box. Chop another small hole so you can feed wire down to wall box. And then install beautiful crown molding to hide the mess, and paint the room so you need new furniture.
Oct 02, 2010 | Electrical Supplies
I bought a hubbell hbl 1386 3 way switch. 2 pole. i don't know where to attach the 3 lines from the outlet to the switch? the drawing says to put red on L2, black on L1. Not sure where white goes. I don't...
What are you using the three way switch to control? A light? Or the socket outlet you are talking about? A three way switch is used in conjunction with another 3 way switch to allow you to turn something on and off from two different locations. If you are only controlling the outlet, then you only need a two way switch. In either case, the white wire, which should be the neutral wire (but don't count on it without testing), does not get fastened to any switch terminals. A switch is used to break the hot (black) side of a circuit. A three way switch used in conjunction with another three way switch also breaks only the hot (black) side of the circuit, but it does it in two different configurations for the two different switch positions.
Sep 12, 2009 | Hubbell Hbl1203 3-way Switch
Leviton 8299 Combination Switch / Smart lock GFCI Outlet Leviton-
power coming in from the breaker box: black wire will go to line-hot screw, and the white wire will go to the line-white screw. the switch wires coming out of the back of the gfci- 1 will go to the load-hot screw & the other black wire will wire nut to the black wire going to the light. the white wire going to the light must go to the load-white screw.
Apr 12, 2009 | Leviton 8299 Combination Switch / Smart...
I need instruction manual for a gfci recepticle and switch combin
Apr 12, 2009 | Leviton R01-7299-0NI Switch And GFCI...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Electrical Supplies Logo
389 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
