Question about John Deere Garden
John Deere 160 lawn tractor.
I'm still have problems with my John Deere160 lawn tractor. The engine is still hunting. I used carb cleaner, always use premium gas, no ethanol. I didn't check the fuel line to the tank, a pain to get at, everything else looks good. Anymore suggestions ? Thanks for your previous help. Mike
  • 708 Answers
May have online fuel filter in line, need to check. Also could be wear in throttle shaft or housing in carburetor.
Posted on Aug 12, 2017
  • 323 Answers
SOURCE: Engine stopped running while cutting grass.
You may have accumulated a little trash, perhaps a little water, and general gunk in the bottom of your gas tank. Either that or a bad fuel pump.
I'd get a new fuel filter, clear plastic kind, and if you have an air compressor or access to one, block the opening of the gas tank, blow compressed air into it, and see if ugly stuff comes out of your tank.
Watch out for blow back out of the tank. I use an old natural sponge like you'd wash a car with, mash it down hard agaunst the openingm and put the blow gun down into the middle. It will take a little while for the pressure to build up enough to blow the stuff out.
Make sure you have the hose down in a can or plastic jug. If the gas comes and freely and is clean, suspect the fuel pump. The filter should have plenty of gas running through it.
Sirwriter
Posted on May 18, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
VtToolMan
  • 704 Answers
SOURCE: Can you assist with a John Deere lawn tractor? I
Leo, try removing the fuel bowl first and checking to see if the needle valve and float are working correctly.
Typically, whenever the fuel system has been "shellaced", the small port that lets fuel flow from the bowl into the carb, gets clogged. You can check this by removing the center nut on the bowl to drop it down. (turn off the fuel valve 1st) and be careful not to let the needle valve and spring retainer fall off the float.
Once you've done that, you can spray some Carb & Injector cleaner thru this port and use a small pipe cleaner to make sure the hole isn't clogged. Also, check the float to see if it's got any gas in it. If it does, you'll need to replace the float, as it shouldn't have anything but air in it, hence the term "float".
You should be able to get the carb working fine after doing the above, since you can get the engine running by spraying cleaner (starting fluid?) into the carb.
Here's a link to the B&S site where you can get info on your particular engine by using the model number stamped on the engine itself.
http://www.briggsandstratton.com/maint_repair/manual_and_more/
Hope you find this Very Helpful and best regards!
Posted on Aug 29, 2009
mickey813
  • 472 Answers
SOURCE: Tractor starts then shuts off, smell flooded
ck the seat saftey swicth thay go bad
Posted on Feb 21, 2010
dumpfixxer
SOURCE: I have a John Deere 116 not getting gas to the filter or carb
it has a vacuume operated pump under the battery, by the steering column .it operates inconjunction with the pump screwed to front of the carb. id check the diphram in both, they dry rot and stop pumping if they sit
Posted on Sep 26, 2013
Hi, problems with my john deere 160 lawn tractor.
Ok there are so many things to go over. Have you checked the carburetor bowl? Be careful to unscrew it an clean out any old debri in it. The fuel today has ethenal in it an collects water. I go to a station that sell gas without it. Mowers an tractors hate ethenal. Then clean out the mail jet wit compressed air or carb cleaner. Also check the valve lash, these engines have a tendency to go out as time goes by. You could have a blown head gasket, check to see if you notice oil or blow by around the head or heads. Check your fuel lines for cracks, if they are old they will feed the carb to much air. I could go on an on, but do some checking with the carburetor that is most likely your problem.
Jul 18, 2017 | John Deere Garden
John deere LT180 runs rough and must use the choke to stay runing, what should I do?
remove the carb take it apart and soak in in carb cleaner for 24 to 36hrs clean out all the passages and that should do it
Aug 03, 2012 | John Deere Garden
John deere gx345 has no spark at plug what is the cause?
need new coil pack or have short in harness grounding engine from running. check fuel line to carburator. 1. take float bowel off bottom of carb. do not touch float or pin holding float. crank engine over until fuel comes out of carb. If fuel comes out, you don't have fuel problem. put float bowel back on carb. 2. check for spark. take spark plug out of mower. put wire back on plug and place the threads on head [or metal of engine to ground the plug]. crank engine over for a few seconds to see if plug gets spark . [always double check with another spark plug that is good]. [[ Remember!!! you have to have someone sitting on the lawnmower to start. unless you by-pass safety switch [only do this if you understand how the safety switch works. NOT EXPLAINED HERE!!!]] If spark is present, there is no grounding problem. when engine is cool. 3. CHECK COIL PACK. for continuity. When the coil pack gets hot it will stop any juice to the plug. A>Check temp sensor B> Check Safety switches grounding out. C> Check for cut wiring harnes. [loose wires rubbing against pulleys, wires cut by rodents]. Hope this helps.........................GAS
Jun 13, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Our John Deere 160 lawn mower wont start. Installed new carb, fuel filter, battery. Has spark but wont turn over and run.
if the engine doesn't spin look at the starter if it has spark and a new carb is there power to the solenoid on the bottom of the carb does it fire on carb cleaner?
Apr 27, 2012 | John Deere Garden
I have a john deere 240 lawn tractor. It will not turn over. Bat. has 12.45 volts. i think my electronic pto switch has gone bad. Any way to check it?
Engine wont turn over on lawn tractor. There are several kill switches that could cause the problem. The seat switch, electric pto or the clutch switch. There are also fuses in the electric circuit that could be blown. If you hear a clicking sound when you turn the key then it could be a weak battery, weak starter or the engine has locked up. If locked up remove plug and squirt oil in spark plug hole. Sometimes that helps if cylinder has been flooded with gas.
Feb 04, 2012 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Aug 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Only idle
Take that carburetor apart and soak in carburetor cleaner and run a small wire down each passage and blow out the passages with compressed air.
Aug 22, 2009 | John Deere 3010,3020 Tractor Basic...
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
