Question about Pool & Spa
I need to replace a capacitor on well pump it's a 1 horsepower it has a 50uf 230v capacitor will it hurt motor to replace it with a capacitor that is a60uf 330 v
  • 1383 Answers
SOURCE: rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Posted on Dec 14, 2008
KMusselmann
  • 247 Answers
SOURCE: got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
Posted on Mar 18, 2009
TheMobilian
  • 8220 Answers
SOURCE: HVAC Blower Motor Replacement
Ain't nothing to it. Slide out the blower and take it outside. Use some rust buster to get the blower out. Don't beat on the shaft. Spread that shaft and the wheel won't come off. Use a rubber mallet. Most generic blowers have white as a common wire and the speeds are black-hi blue med and red, for low. 2 brown wires will go to the capacitor. other wires will reverse direction. Wash the housing and blower wheel good. any wire unused will be taped off to themselves. Nothing to it.
Posted on Mar 11, 2010
MOTORWIZJ
  • 1338 Answers
SOURCE: The pump comes factory set for 230v. Power to the
CHECK YOUR BREAKER IT MIGHT BE THAT YOU ARE 230V .. IF IT IS A WIDE BREAKER ITS 230 OR IF IT IS A SLIM BREAKER ITS 115V , A VOLT METER IS YOUR BEST FRIEND.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Posted on Jun 30, 2010
john224
  • 1378 Answers
SOURCE: i need to replace the
Yes, that is a run capacitor. You will also need to clarify oval or round design.
You should take the old one in to a local electric motor repair shop if it is not obvious it is blown. Even if it is, their will be other issues that caused the capacitor to fail in the first place. You will want to try to identify those and fix them as well or you will be replacing the capacitor again soon.
John
Posted on Dec 05, 2010
Motor not working.
You need to find out what is causing the capacitor to short and "blow up or smoke". Then you will have to replace the capacitor again or the motor will never start up. Sounds like you either have a dead short or you bought a faulty Capacitor. Not uncommon for a 220+ volt Capacitor to be bad right from the factory. I replaced two Capacitors before I had a quality one, but after I replaced it twice I have had no more problems. Make sure to grease the motor through the grease fitting on it. The life of your motor depends on it.
Nov 09, 2013 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Motor won't turn on
CHECK POWER AT THE PUMP, MOTOR BUZZES ? YES CHECK TO SEE IF ROTOR TURNS, YES CLEAN START SWITCH, HAVE CAPACITORS CHECKED , NO ROTOR DOESN'T TURN MOTOR WILL NEED TO BE SERVICED. ROTOR MAY HAVE RUSTED TO STATOR OR LOCKED UP BEARING .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 15, 2012 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I have a older spa with a Sta Rite pump motor. Without removing the damaged pump I was able to see the model number of the pump through a mirror. I beleive it reads K48M5A3, is there any way that you can...
That would definitely be the model number. The K indicates Capacitor start and run, the 48 indicates the frame size, and the "M" indicates horsepower (1.5 hp, in your case). If your replacing the motor, make sure you get the same Horsepower and Service Factor ratings. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 12, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Pump makes a noise for about 10 seconds then turns off. Wont pump. Repeats this over and over
Try a start capacitor. or if the pump won't turn by hand take the pump apart and make sure nothing is broken inside. If still nothins it is probally a bad motor and you will need to replace.
Jun 27, 2010 | Waterway Champion 1 1/2 Hp 230v Energy...
Can you tell me what kind of torque a 1 1/8 hp 115 ac ge motor has?
Thank you for posting your question here on Fixya.com.
Not a GE but the numbers should be very close...
Load (% of horsepower) Torque (OZ-FT)
0.25 7.0
0.5 12.0
0.75 18.0
1.0 24.2
1.25 36.6
I believe what you meant was that you have a 2 speed, 1 HP high, 1/8 HP low motor…these numbers are for the high speed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 13, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Just replaced a rheem oem 1/6 hp motor 3 wires with a 1/3 hp 5 wire. Need help with wiring diagram. A.O. Smith 1/3 hp to capacitor
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Jul 07, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
