Question about Samsung Televison & Video
On main board of a Samsung p51e8000 none of the hdmi ports work all other port type work. Need options. Do I need a new main board? Or is there another option.
  • 22 Answers
SOURCE: blue screen arrives ...system not working
At bootup press F9 to restore to factory condition
Posted on May 23, 2009
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
SOURCE: All of the HDMI ports on my JVC lcd tv are not working.
I had the same problem on mine. It is a factory defect. It means your HD box that controls HDMI, USB, and RED GREEN BLUE component. Usually the red, green, blue, (720 HD) component is still functional, but the HDMI and USB are shot and can only be replaced not repaired. If your warranty is still valid and you have your receipt call JVC and they will give you the number to a certified warranty repairman. If you do not have the receipt they will not fix it. If you do not have the warranty and decide to repair it yourself or send it out, the fix is not difficult but it is costly. The box is about $1000.00 and the labor varies. The last option is to sell it for parts. If you decide to do this I will purchase the broken television from you. But if you have your warranty info there is nothing to worry about.
Posted on Aug 02, 2009
tlm931
  • 273 Answers
SOURCE: HDMI socket board replacement
you would have to get a exchange module that has the av ports as well as hdmi jacks you can either order a service manuel to obtain the part numbers or call sony have your model and serial at hand when you call
Posted on Oct 24, 2009
Testimonial: "Thanks - Sony already quoted £300 - at that cost a new TV would be cheaper!"
SOURCE: I have HDMI port on back of Gateway. I plugged a
Hello, I have a Gateway DX4300,For the HDMI to be detected you need to power on the device it's conncted to
Posted on Dec 11, 2010
Samsung model LN52A630M1FXZA HDMI ports don't work.
The problem is the main board, you may look at the stick on the main board to find the part number (usually as BN96-XXXX), you may find a used one from EBay.
Jan 15, 2018 | Samsung Televison & Video
After installing the new main board is there any type of boot procedure that needs to be done, or should it just work like new. this is for a Samsung model#un46h5203afxza version#tdo1
In most cases, after the main board replacement, a software [firmware] update too might be necessary.
If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Aug 04, 2016 | Samsung Televison & Video
Samsung Plasma PN64D7000
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 17, 2016 | Samsung PN64D7000 64 plasma 1080p 3D HDTV
Hello I just purchase my new HDMI port How to replace my broken HDMI port are install a new one
Removing the old HDMI port from the main board and replacing a new one is a highly skilled soldering job. Please do not attempt it if you are not expert at it. You may end up ruining the main board. Taking the services of an experienced technician will be a better option.
May 19, 2015 | Televison & Video
Pioneer pdp-5070pu HDMI port 5 has a megenta hue to it. All other HDMI ports and component ports are fine. What board might need to be replaced?
The main board that has the HDMI ports on it. The numbers can be taken from the board itself. Once the board is replaced, you'll have to go thru all the setup menu's because the memory is on that board too.
Dec 27, 2013 | Televison & Video
Sylvania hdmi port not working
Sounds like you may need a new main board.
Jan 27, 2018 | Sylvania LC320SSX 32 in. LCD TV
Hdmi2 is not working
The HDMI port has failed very common problem if another drops out soon you will no doubt need to replace the main board as usually they fail one after another if its a main board issue, If just the one fails then its most likely just the HDMI port itself which has failed and replacing just the port should repair the issue. You can get replacement HDMI ports and also complete main boards from www.tvcircuitboards.com
Dec 11, 2012 | Televison & Video
HDMI PORTS DONT WORK
You will need to replace the main video logic board, its part number is either EBU60852909 or EBU60852911. These two board are direct replacement parts. There are several boards available on Ebay such as this one: http://www.ebay.com/itm/LG-46LD550-UB-Main-BPR-Total-Assembly-EBU60852909-subs-to-EBU60852911-/150895037335?pt=US_TV_Boards_Parts_Components&hash=item23220b8b97
Sep 11, 2012 | LG 46LD550 46 in. LCD TV
46" Samsung LNT4661FX /XAA LCD TV volume problem.
If sound on one HDMI and not the others---all three should go to the same board--either something is not connected inside or the replacement board is the issue---Samsung is known for making boards with the same part number on them that from week to week have different features or do not have certain features.
Try to trace where the working input goes and if to same board as other two you know what to suspect.
Jun 15, 2012 | Samsung Televison & Video
I have a kde-50xs955 sony plasma tv and now hdmi port stopped working. tried with new hdmi cables but no luck. cut power to reboot still not working. tried different devices and wont show it is even...
HI:
You need to replace the analog board assembly, this is the board that you plug connections into, seems the HDMI port has malfunctioned, there may also be a problem with the main board assembly that the analog board connects to.
Jan 24, 2011 | Televison & Video
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
