Question about Sewing Machines
Blue spruse needles falling off starting at bottom how can I help it
  • Sewing Machines Master
  • 11,177 Answers
And this is in the sewing machine category because...
Posted on Aug 12, 2017
How to change needle
Depends on your sewing machine. There is a screw that holds the needle in place. Unscrew it (don't let the needle fall into the bottom of the machine!). Pay attention to where the flat side of the needle is positioned in the needle holder! Then just insert a new needle with the flat side facing the same direction, push the needle up as far as it will go and tighten the screw.
Jun 20, 2017 | Sewing Machines
My needle keeps falling out. I unscrewed the set screw, put the new needle in, then it falls out. I had just taken out an old needle by unscrewing the set screw and didn't touch anything else. Help
Be sure to unscrew the set-screw and extra turn and then insure you are pushing the needle all the way up before tightening it. Could also mean the set screw is stripped...
Dec 11, 2016 | Sewing Machines
Bobbin falls out of its place
the tip of the needle may be loged in the inside of the hook so the bobbin does not fit flush. do u hear a click when inserting the bobbin case?
Apr 29, 2014 | Juki Sewing Machines
Empisal dressmaker 270d
Loosen your needle. Turn your handle towards you. You may have to turn a little hard. Now, throw that needle away.Take your fabric away and check the area where your bobbin goes and clean it out of fabric and thread. Now load your bobbin again and load a new needle. Pull your thread up from the bottom by turning the handle towards you while holding the needle thread with the foot down. Now look and place something under the foot and slide it forward while still holding the needle thread. The bobbin thread should come up. Let me tell you this though. Adjust the bobbin thread before you start. This is done by placing the thread in the carrier (usually unwinding counterclockwise) and place the thread under the tension spring. Hang this from your finger and bob it up and down lightly. It should fall about one inch. If it doesn't then loosen. If it falls too far then tighten.
Apr 27, 2014 | Sewing Machines
Needle broke off in sewing machine
Usually they fall to the bottom. Slightly shaking the machine can tell if it is still there. A small magnet is sometimes helpful.
Mar 20, 2014 | Brother Sewing Machines
SINGER MODEL 3130 WILL NOT STITCH CORRECTLY
Have you tried cleaning and oiling your sewing machine.Sometimes old thread gets caught up under the pressure foot near bobbin if not cleaned out the bottom teeth that pull material through will not move bobbin thread up to be caught by needle thread. P.S. Are you sure your using the right needle for the machine? To short of a needle will also cause this problem
Apr 10, 2012 | Sewing Machines
How to replace needles
Your problem has been posted against the Elna 2007 mechanical sewing machine - not sure if this is your machine but it shouldn't make much difference. All domestic sewing machines have very similar needle placement.
The needle bar is the piece that goes up and down and holds the needle. There is usually a housing at the bottom with a thumb screw that is used to secure the needle. To change, turn your flywheel towards you until the needle is at its highest point. Turn off the motor or unplug machine for safety. Hold the needle with one hand and undo the thumb screw with the other. Insert a new needle into the housing FLAT SHANK TO THE BACK, all the way up into the housing, then tighten the thumb screw.
Standard domestic sewing machine needles are coded 130/705H and almost all makes and models will use this type of needle. Industrial machines are different and some overlockers/sergers will use a slightly longer needle called ELX.
The important thing is to change the needle regularly, about 4-6 sewing hours is maximum before the point starts to go blunt. If you can hear a squeaking or popping sound as you stitch, this is most likely a blunt needle. Also use the right sized and type of needle for the work you are doing. So for knits and jerseys, use a ball point needle to avoid skipped stitches. For lycra use a stretch needle coated with blue, helps with this synthetic fibre.
For wovens, use a sharp or universal point but pick the right size for the weight of fabric. Sheers, organza and fine silks, use a 60. Lightweight cottons, use 70. Medium weight fabrics use a 80 etc, right up to 110 size for coated upholstery fabrics. There are special needles for denim too as this is a very densly woven fabric so again, a blue coating helps to get the needle through the fibres.
I trust this helps you to resolve your problem.
Sep 28, 2011 | Elna 2007 Mechanical Sewing Machine
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
Singer zig-zag 437
loosen the screw on the larger of the two feed gears (not bevel gears). Retigten so that the feed teeth start to rise right when the needle starts to rise and fall right when the needle starts to go into the fabric. Make the setting the same. i.e. when the feed teeth start to rise, how high is the needle (2mm, 3mm, etc.)? set the feed timing so the teeth rise and fall with the needle at the same height going in and coming out, this assures that the fabric only feeds when the needle is out of the fabric.
kent
Mar 18, 2009 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
