Question about Cub Cadet Garden
I HAVE A CUB CADET LT1045 AND THE SWITCH WILL NOT KILL THE ENGINE
    Loyalty:
    Visited the website for 30 consecutive days.
  • Cub Cadet Master
  • 1,204 Answers
Sounds like the ground in switch is not doing its job check and see if the ground on the coil is there if so the switch may be bad you can replace it or put the ground on a on anfd off switch.
Posted on Dec 18, 2017
  • 78 Answers
SOURCE: How do you remove the front tire on Cub Cadet
Thats a plastic dust cap.Remove it very carefully so not to damage it. Then under the plastic cap will either be a Cotter pin or and E clip remove what is there and slid the tire and wheel off the spindle. These are a bear to break down and dismount and or remount. Unless you have a mini tire changer. I use my huge vise and a shaft the size of the spindle.I use motorcycle or bicycle tire irons. ITs a hassle believe me.
Posted on Oct 22, 2009
  • 203 Answers
SOURCE: Cub Cadet LT1045 oil light
I am thinking that might be a notice to change the oil, which is only for notification purposes. Check your owners manual. There may be a procedure to reset the timer when you change the oil.
Posted on Sep 04, 2010
woobie dog
  • 1273 Answers
SOURCE: I own a Cub Cadet Hydrostatic Lawn Tractor, not
Hello, W/D here.
Without a particular model number, I'll have to be somewhat generic, so forgive me in advance.
The fact that the mower will run and the blades will engage is good news; it eliminates about half of the things that would need to be checked.
Look for a lever at the (usually) back of the tractor, on the back plate, down low. Sometimes called a range selector or a disengagement lever. Normally, the position of this rod is "IN". If it has pulled towards the "OUT" position, the transmission is disengaged. Usually this rod is pulled out when you want to push the mower, and I expect you're tired of that by now! Chech and see if this is the issue, and post back if not.
Regards, --W/D--
Posted on Mar 07, 2011
  • 3074 Answers
SOURCE: wiring schematics for 2007 cub cadet lt1045 need
this should help Tim:
http://cubcadet.custhelp.com/app/answers/detail/a_id/1722/~/cub-cadet-technical-service-manuals
Posted on Jun 04, 2011
  • 5 Answers
SOURCE: cub cadet model LT1045 belt coming off the pulley
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Posted on Jun 22, 2011
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Engine will not crank on lt 1046. New battery. Seat switch is working. Seems like the clutch safety switch. Any ideas. thanks. Bill
both the seat and clutch safety switches must be working for the unit to start, ( or at least for checking purposes be Jumpered) but for your unit check this link for a breakdown of your machine (Lt1045 anyway ) http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
May 27, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet model LT1050, when i release the brake the engine wont stay running, but starts and runs fine if i hold the brake in
I believe the problem is a safety feature which is connected through the RMC, like the seat switch, just do a search for RMC on this PDF Manual it will show you how to check and what does what, Hope it helps and Good Luck Tim:
http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02100.pdf
May 20, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a 2007 Cub Cadet Series 1000 Model LT1045 Does this model have a drive belt or is that belt just to run the fan on the tranismission.
hi there pauly46 here your model 2007 and before lt1045
take a look at this web site
this takes you stright to transmssion / belt drive system
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29&dn=0125500003
this diagrams shows belts etc in the drive system , fan, trans etc
your answer is it does have a trans belt it is part number 954-0461
was pt number 754-0461
take a look at this site
cheers hope it helps
pauly 46
Diagram: LT1045+Tractor+%282007+%26+before%29 Drive System 1I136H & before CUB Cub Cadet 954-0461 (replaces 754-0461)
Apr 29, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I don't want to talk to an expret , I lost my manual and I need one to repair my Tractor Cub Cadet lt1045
OK, I won't talk :)
Here is the direct link: http://www.hammerwall.com/Download_Manual/13295/ if the link gives you problems do the following.
Go to www.hammerwall.com and put in Cub Cadet lt1045
Jan 14, 2011 | Cub Cadet Garden
Garden Logo
37 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
