Question about Sharp Audio Players & Recorders
Sharp CD MPX850 radio wont scan no remote
Got it used no remote cant scan for radio stations, do you need the remote or to reset the whole unit, no antenna yet either.
3 Suggested Answers
SOURCE: GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
Posted on Aug 07, 2008
gopakumarg43
  • 75169 Answers
SOURCE: I need a remote for the sharp cd-mpx850. I can't change the station.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Posted on Sep 14, 2016
Ca900 radio wont work - the radio lights up as expected but the main area that normally displays what station yo are listening to is blank. No sound comes out except from the beeps when pressing buttons on...
Hello Dan, have you tried to reset the unit using the reset button behind the front panel? also try to clean the panel metal contacts, clean them using a cotton swabs or an handkerchief wet with alcohol, both side (main unit & detachable panel)
Oct 23, 2013 | Car Audio & Video
Remote control for sharp cd-mpx870 will not work
Use rubbing alcohol and a Q-Tip to clean battery terminals,and use fresh batteries.
Apr 21, 2012 | Sharp CD-MPX850 Shelf System
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
I CANT GET THE FM/AM BAND TO WORK
Connect a good FM antenna to the unit's antenna jack to make sure you get good radio reception. Power on the unit. Press the Tuner/Band button. Adjust volume and tune to a known station using the up or down arrow buttons..
Mar 05, 2011 | Sharp CD-MPX850 Shelf System
My sharp cd-mpx850 won't turn on
The cause could be a blown fuse or the power transformer that has a built in thermal fuse has opened preventing power to the rest of the stereo. The main unit must be taken apart to assess the amount of work needed and to check for secondary problems.
THE SYSTEM SHOWS ME ER-CD01 AND ALSO THE PLAYER WONT PLAY THE CD, IT DOESN'T EVEN READ THE CD
this is a standard reset so if its a problem with the programming this should do the trick if it does not either your cd or laser lens is no longer doing its job properly
turn on the set-press the on stanby button,allow the set to enter demo mode. now press the power button while pressing the stop and eject button,clear all will display
hope this helps
Robb
Apr 23, 2010 | Sharp CD-MPX850 Shelf System
How to reset sharp cd-mdx850
Mar 25, 2009 | Sharp CD-MPX850 Shelf System
Cant set clock or access menu using universal remote
Haven't found answer to that, but there is a remote contol specifically for your unit now on EBAY at http://cgi.ebay.com/SHARP-VCR-RRMCGO173AJSA-Remote-Control_W0QQitemZ350117240995QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116. The whole thing is under $10 including shipping. If nothing else, copy the model # of the remote and you might be able to find it cheaper someplace else.
Dec 04, 2008 | Sharp VC-H973U VHS VCR
47 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
