Question about Whirlpool Microwave Ovens
My Whirlpool microwave randomly makes a growling noise (with vibration) when not in use. It seems to be coming from the top above the fan area. Something going out?
    Sergeant:
  • 224 Answers
Sometimes a bad relay on the main timer board will tell the unit to heat with nothing in it and it will arc in the wave guide or antenna area. Arcing sounds like growling or grumbling. "Random" may be from the relay sticking sometimes and then sometimes not. Will destroy the wave guide and the magnetron and the unit could not be repaired. Would have to be replaced if that happens
Posted on Aug 24, 2017
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker XL 1800 - Noise while heating
Maybe you and the person from the post below could get together and help each other? http://www.fixya.com/ThreadView.aspx?prdid=489218&thid=130453
Posted on Mar 29, 2007
SOURCE: GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
Posted on Jan 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Loud noise coming from turn table
The turntable system consists of the turntable motor, the turntable coupler, the roller guide / turntable support with rollers, and the glass turntable tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
It's important for everything to be clean and dry. Lubrication is not recommended or required. That would only serve as a bandaid.
If it doesn't work right, or it makes noise, then it is broken or worn.
For more help from Magic Chef / Ewave see here or their contact page or you can order replacement parts here.
Posted on Nov 23, 2008
  • 1214 Answers
SOURCE: wall mounting needed for a top mount microwave/hood combination
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
Posted on Jan 29, 2009
rylee_smith
  • 8619 Answers
SOURCE: i have a ge above range spacemaker xl1800 it seems
The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade(look for part #80) is slipping on the motor shaft ( the noise you are hearing).
GE XL 1800
If the blade is broken then you can buy a new one from---
GE FAN BLADE
Please ask for further clarifications.
A Fixya rating would be appreciated if you find it useful.
Thanks
Rylee
Posted on Feb 24, 2009
Microwave occasional loud buzz
make this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 14, 2013 | Jenn-Air JMV8208AAS Microwave Oven
GE microwave occasionally buzzes loudly.
Nov 14, 2013 | Microwave Ovens
Gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    Microwave makes sound like something moving inside
    follow this steps and use the VOM , and fix it. God bless you
    Jun 18, 2013 | GE JVM1490 Convection/Microwave Oven
    Coleman EB15A - Buzzing noise from transformer area, no heat or fan
    see this causes and proceed. God bless you
    Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
    Exhaust Fan Motor If the microwave is loud when running the fan motor might be
    Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
    Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
    Oct 18, 2012 | Microwave Ovens
    GE Microwave (JVM1860CD001) control board buzzes.
    see this causes and fix it. God bless you
    Oct 10, 2012 | GE Microwave Ovens
    Whirlpool mh1160xsb over range that buzzes when cooking
    It depends on if it is just a loose component that needs tightened up or if it has started failing. it will require some investigation and trial and error to resolve. I have had some success in resolving vibrations and some were real challenges. It is a matter of isolating the noise maker and seeing what can be done.
    Eric
    Oct 04, 2009 | Microwave Ovens
    Mar 25, 2007 | GE JVM1660 Microwave Oven
    Jvm1440bd Microwave
    I thought I had answered this, but maybe the reply didn't post... Vent cap? Could you be more specific about what you tried and what the noise is like - where it seems to be coming from? It looks like on some of these models, the high-voltage section emits some interference which some people are blocking with a foil or metal shield. If they do that, they should definitely insulate it to prevent shorts. Another cause of vibration on these models is a fault in the stirrer located above the cover on the ceiling inside the cooking cavity. Feel free to post back so we can help further.
    Jan 08, 2007 | GE JVM1410 Microwave Oven
    Microwave Ovens Logo
    53 people viewed this question
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
