Question about Intex Pool & Spa
Intex Pure Spa has turned off overnight with no error code just nothing :-( We have tried re-setting, unplugging etc but nothing has made any difference. It is not even 3 weeks old.. Any suggestions?
    Top Expert:
  • 12,744 Answers
If no power check and test the ground fault plug --then need to check connections in tower
Posted on Aug 12, 2017
    Top Expert:
  • Intex Master
  • 41,752 Answers
Your spa power source may have failed completely.
SOURCE: My machine doesn't run. Sounds like it's trying...
http://appliancejunk.com/ge/washer/31-9135.pdf
Above is your service and repair manual, this is what the engineers use to troubleshoot and repair these units. Below, and two DIY self help washer repair self help websites. http://www.repairclinic.com/Washing-Machine-Repair-Help
http://www.washerhelp.co.uk/diy-repair-help.html
Posted on Jun 01, 2010
jerry_kramer
  • 3904 Answers
SOURCE: intex spa
You have a bad GFI plug. Replace it and you should be fine.
Posted on Apr 13, 2014
  • 1631 Answers
SOURCE: We have a LED code showing on the new Intex pure spa. E97 Dry-fire Protection. What does it mean
Dry fire protection is when the heater has a call to heat but it is sensing NO water flow, therefore heater will be disabled.
A dry fire is when the heater comes on with NO water flow - damaging your heater beyond repair.
Causes: No water in tub, closed valves, clog restricting water flow, or the pressure/flow switch had failed?
Posted on Apr 11, 2015
  • 1631 Answers
SOURCE: Please help I have a intex pure spa and it has
According to Intex - E96 is a "System Error", and the most common problem associated with that fault code is a failed GFCI Cord End.
Look here for replacement;
Leviton 16693 15 Amp 120 Volt Grounded Compact Automatic Reset Right Angle...
E70 and E90 error code on intex pure spa pump... what do these mean and how do I fix it?
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check with Intex for a repair manual ( On line and google..)
Feb 25, 2016 | Intex Pool & Spa
My Intex Pure Spa will not turn on. It is about 4 months old, just makes a high pitchd squeal and nothing on the display. Help.
Most likely something to do with the pump or motor. If it has a clean-out basket check that and make sure nothings blocking the way. Your impeller might be destroyed/jammed or it could be motor failure, bearings any number of things.
Jul 22, 2015 | Intex Pool & Spa
I have an "Intex Pure Spa" inflatable spa. It shut itself off. when I push restart it starts up then in about 10 sec an "E" comes up on the screen and it beeps. What can I do to reset and fix the err
Has your problem been resolved?
Please use 'Comment', and inform the forum here of your experience.
What did you do? Did Intex help?
If you are still dealing with this problem, let us know.
If so, and for anyone else with a problem ...
Support Intex
Jan 30, 2015 | Intex Pool & Spa
I have an Intex Pure Bubble Intex Pure Bubble Spa. The filters do not have any suction. Are they supposed to? If so how much? I do not feel anything.
For a test only, remove filters and see if you feel anything against the fitting?
If nothing either 'Air Lock', keeping it from priming the pump.
Or, bad pump!
Secondly, are you still dealing with a problem?
Use the comment link on this thread, and let the forum know if you are, if repaired, what did you do?
Intex link...
Support Intex
Jan 22, 2015 | Intex Pool & Spa
Aug 03, 2013 | Pool & Spa
Pool & Spa Logo
64 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
