Question about Sewing Machines
My needle holder has moved to the left and hits the faceplate
  • Sewing Machines Master
  • 11,205 Answers
Service is probably the best option.
Posted on Aug 12, 2017
SOURCE: Bobbin holder problem. Needle hits bobbin holder
Is the needle all the way up in the holder? Have you checked the timing with the bobbin and the needle. Look in your manual for needle timing
Posted on Mar 04, 2009
  • 97 Answers
SOURCE: Needle hits the bobbin holder and doesn't grab the bobbin thread
Also note that using a red band Singer needle will cause this exact symptom. The Singer needle is about 1.5 mm too long for use in any other machine. Ensure that you're using a standard needle. (Schmetz and Klasse are good examples.)
Your machine may also be out of time, which would require professional repair.
-R
Posted on Mar 11, 2009
  • 3 Answers
SOURCE: The needle on Our Kenmore 15218 is hitting the
Did you try putting in a new needle? And is the needle put in correctly? Otherwise , I am not sure about this one...I had that happen to me once, and putting a new needle in corrected it.
Posted on Mar 16, 2009
  • 96 Answers
SOURCE: My needle keeps hitting the plastic bobbin holder
change the needle and see if it is still hitting because once they hit the case or the feed dog they very often get bent always change needles with different fabrics and types of thread
Posted on Dec 13, 2009
  • 23 Answers
SOURCE: sewing machine 'popped', and needle is hitting
Adjust the metal plate to fix the needle hitting problem.
Posted on Apr 13, 2010
How to position the needle
The needle will rise in the holder in only one direction. If you would turn it in any other direction it go up in the holder. Most needles have the flat part in the back or on the right side. Old black Singers is reversed where the needle has the flat part on the left.
Nov 16, 2016 | Sewing Machines
Pfaff 7570 needle hits with ruffler installed
then quit ruffling LOL I know not funny can not think putting it on changes the place where needle goes down
Aug 30, 2015 | PfaFF Creative 7570
Simplicity sewing machine SL 9240 was giving to me and when I try to sew the needle keeping hitting the bobbin holderr.
On the right side you have two knobs to make adjustments. The lower knob will move the needle left or right so it won't hit the bobbin holder.
May 31, 2014 | Singer 7442 Mechanical Sewing Machine
How to adjust placment of twin needle so it doesnt hit edge of bobbin holder?
The needle should not hit the bobbin holder at all. Do you have the needle inserted all the way? If it is too low, it will hit. If you are saying the needle is hitting the sides of the needle plate where the needle goes through, then the needle is too wide for the plate. Either use a narrower twin needle or see is a needle plate with a wider needle hole came with your machine. Some decorative stitches can't be used with a twin needle because the combination of width of stitches and width of needle is too wide. In that case, narrow the stitch width until the needle doesn't hit the needle plate or use a narrower twin needle. I hope I have helped and answered some of your questions. Good luck.
Apr 26, 2014 | PfaFF Sewing Machines
Hi, sounds to me like you haven't refitted the bobbin correctly
Regards
www.electronicrepairs.co
Dec 27, 2013 | Brother CS6000i Computerized Sewing...
Pfaff 1472
make sure that the needle was put in the needle holder correctly and tightened into the needle holder correctly..
if the needle was in the needle holder correctly and it's still hitting the bobbin carrage then the machine needs to be checked to see if the sewing machine needs a adjustment
Aug 17, 2013 | Sewing Machines
Can't adjust tension
is it the right needle for the fabric being sewed?
you said you put in a new needle and as you tighen the screw
the needle moves to the left,, it's a possibility that the needle holder or
needle bar need to be checked because the needle should stay straight
and not move to the left unless your changing the needle position.
could the top thread be caught somewhere, like the spindle the spool
set on, I've had that happen, if possible take a can of air and blow the
tension disks just incase there is any lint in them.
Nov 05, 2012 | Sewing Machines
The right needle on my babylock keep breaking
Perhaps the needle is not fully pushed in or not tight in the holder or has the needle plate moved and the needle is now hitting it? A bent needle will break as it hits the plate but apart from that I cannot imagine what is causing this.
May 04, 2012 | Baby Lock Sewing Machines
Needle hitting bobbin case holder following loud needle breakage.
try these sites they might have a video that would help
youtube
fixsewingmachines.com
Apr 05, 2012 | Sewing Machines
Needle hitting bobbin plate
Is the needle inserted correctly with the flat side at the rear and fully up into the holder ?
If yes, take off the needleplate, remove bobbin case and slowly rotate the handwheel towards you watching the relationship between needle, and the "hook" of the moving "race".
Set on wide zig zag........when the needle is fractionally past it's lowest point, and starting to rise, the hook should be level with the left side of the needle when on the right hand stitch of the zig...the eye of the needle will be below the hook, and ready for thread to be picked up for the stitch to form.
Any other result will mean your timing needs adjusting.
Feb 09, 2008 | Singer 7422
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
