Question about Miele Refrigerators
I have a two year old Miele top refrigerator and bottom freezer. It has worked like a charm until now. It is flashing -21 then 01 then _F. Can't figure out why.
Rotu
  • 175 Answers
SOURCE: refrigerator not cooling top shelf
it sounds as though you have a fridge that is low on freon. If the ice is appearing mostly to the left, then thats surely your problem. if it goes all the way across, you may have a bad evaporater fan motor, fan motor switch, bad cold control, or just a door that isn't closing or sealing properly. If its the ice mostly to the left side, it probably means your evaporater is leaking the freon. I am assuming you have a model that has a cold control on the back wall, not the electronic display by your description. If your unit is less than 12 years old by the installation date, the part will still be under warranty (sub zero has an unmatched 12 year sealed system parts warranty) but the labor and freon will not be. The repalcement of that evaporater in my area usually runs about $450 with labor, freon and trip all together. It is a repair you cannot do unless you have an acetlyn torch and some silver-soldering/ brazing ability. If your model is in fact the newer style with the electronic temp display, call sub zero up (the # is on the model/serial tag in the door jamb) and tell them wahts going on. If it is in fact an evaporater leaking on this style, they will most likely pay the bill for you even if its well out of the 5 year full warranty. If you want to know for sure, remove all the shelves, then remove the cover over the lights. Then if its electronic remove the 3 screws holding the top of the back panel and tilt the panel out to you and pull it up and out: if its a dial type, remove the 2 screws holding the fan cover and then tilt the back wall out to you and lift it up and outwards, but not too far as it wil pull the wires of that control knob (cold Control) Look at the coils back there and see if the coils are frosty. If they are only frosty on the upper left of the coil, its low on freon and needs an evaporater. if its frosty all the way across, top to bottom, you need a cold control, or possibly a fan or fan switch. Hopefuly you can wade through all this. Just post back if you have any questions. Good Luck!
Posted on Aug 16, 2007
  • 1462 Answers
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: ringing noise from refrigerator
It's probably a dry bearing on either the compressor or the fan in the freezer. The evaporator, I believe it's called.
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
If it's under a year old, it's probably in warranty. You can get warranty info & find a local authorized servicer from there, too.
To order Goldstar / L.G. parts for a do it yourself repair, visit Vance Baldwin Electronics. You'll probably have to call them.
Posted on Dec 13, 2008
SOURCE: water in bottom of refrigerator
WARNING-It is a condition for the reader to take full responsability in attempting repairs and author shall not be responsible or liable for any damages. If you have no knowledge or experience to do this repair do not attempt it.
I have had the same issue with Fisher Paykel Active Smart fridge . This can be due to:
1) 12Volt fan in freezer is not functioning.
To test: open freezer door, place a magnet on magnet switch at the bottom of freezer where door seals(white plastic rectangle) It takes few seconds for fan to rev up so move magnet slowly until switch on. You can also close door and listen carefully if fan starts if unsure.
If fan works go to 2) 3)as defrosting resistance can be the trouble
2)If fan does not work . UNPLUG FRIDGE at the main plug
Empty freezer and defrost it if too icy (do not use sharp objects). Then on back panel you will see two holes on top. Put two hook tool and pull down and slightly forward until top lip is free. This is hard to do but the plastic panel is very strong so you can apply a bit of force there!!!
On the second panel is the fan, check wires are not broken (common cause of failure). unplug fan, you can check fan on 12V battery (+red). Buy a new fan if faulty and put freezer panel back.
3) If fan OK and you see a lot of ice on condenser (do not remove it by force, just let it melt completely) then the resistance is the cause of you trouble. It is delicate to remove and make sure FRIDGE IS UNPLUGGED! Do not force anything as condenser is very fragile and if you damaged it, your fridge can go straight to the dump. You can test the resistance with an Ohm meter to make sure internal resistance is broken or not. If broken replace it and your fridge will be fixed. If not broken then trouble is either with on board computer (very seldom) or the thermistance.
Posted on Dec 18, 2008
  • 1122 Answers
SOURCE: Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Posted on Mar 16, 2009
Miele bottom freezer / fridge. Main control panel
Electronic is about 150 pounds plus vat
Ring Miele in UK on phone number below.
01235 233133
Jan 10, 2010 | Miele KF7642S Bottom Freezer Refrigerator
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Have a 10 year old kitchenaid bottom freezer--- Freezer works fine, but top box has ver@y little air flow and is warm
Theier is a fan locatred between the two sections. Check to see if it is working. If not clean and lub or replace.
Dec 31, 2008 | KitchenAid Architect KBRA20ERSS Bottom...
MIELE KFN8762SDED (SS/fridge/freezer)
No problem just use the + and - buttons when you have chosen the temp. you want just let go and that is the temp the fridge or freezer will set at.
Aug 19, 2008 | Miele KFN8762SDED Bottom Freezer...
Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
We let the fridge thaw for two days, cleaned it from top to bottom especially the coils and underneath. We moved it outside and used an air compressor to blow out the dust and dirt around the coils so nothing was damaged in the process. It works like a charm and probably more efficiently too. Before it had quit working it was freezing in the refrigerator part. So that was an indicator something was clogged. Moisture that collects and freezes blocks the air from circulating. The freezer worked great! But ice cream was too hard.  Now it's just right.
Apr 06, 2008 | Maytag MBF2256H Bottom Freezer...
Refrigerators Logo
42 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
