When I turned on my tv frog tonight all i can see on the screen is a logo for Rockchip. Can anyone help? Everything is plugged in correctly- HDMI cable etc.
SOURCE: blue screen with HDMI
Check the power supply modular cable connection that is by itself in the upper right corner.  On the one my son-in-law has the double yellow jumper wire that connects to this plug in two locations was loose (not properly inserted) in the modular connector and had worked it way out.
Posted on Oct 26, 2007
SOURCE: HDMI cable between TV and Lifestyle 28
Did you set up your bravia TV to receive pictures throuh HDMI ?
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: connection problem with HDMI cables on Denon AVR-589
Hi dmsgolfer22,
If your Time Warner Cable box is old enough that it has a DVI output it may have HDCP (copy protection issues) with the receiver. If you are having to use a DVI to HDMI adapter to connect to your receiver (output from Cable Box to input on Receiver) then it's very likely your cable box may have may not output the signal because it detects the HDMI repeater in the receiver.
The two best options to correct this are:
1. Connect the DVI to HDMI cable directly to the input on the TV, you lose the convenience of the video switching in the TV, but it will solve the problem. Then connect the digital audio output from your cable box to the receiver, although you've probably already done this.
2. Contact your cable provider and check into the possibility of them swapping out your cable box for a newer model that would have an HDMI output. This would be the best option since the HDMI output on the cable box would give you both the Digital Audio and Video through a single HDMI cable.
Let me know how it works out for your, or if you have any questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Posted on Feb 28, 2009
  • 453 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Posted on May 08, 2009
SOURCE: panasonic th-50pz80 10 flashing blinking red lights
The way to solve the problem with the TH-50PZ80U blinking light problem is to not buy Panasonic Products. I have had my TV about 21 months and it has started with the blinking light problem, just out of warranty. Panasonic is aware of this problem and refuses to do recall or fix the tv unless you are within the warranty or have bought the extended warranty. Legally they are within their rights, but I am also within my rights to air my complaint and inform others of this below par product. Who wants a TV that they have to unplug for a while and pug it in again for it to work. I want to push the power button and it come's on. I will never purchase another PANASONIC PRODUCT.
Posted on Oct 25, 2010
Smart tv box
Have you tried unplugging it from power, waiting at least 30 seconds to 1 minute, then plugging it back in?
Aug 21, 2014 | shop-fun MK808 Dual Core Android 4.1 TV...
Yamaha purple screen rx-v373
I had this same issue. I think I finally resolved the issue by turning off HDMI Control (HDMI-CEC) on my Blu-Ray player. I had the Blu-Ray player plugged into a Yamaha RX-V375 (almost an identical receiver). I think the source of the issue was that my TV does not not support HDMI-CEC. Turning off HDMI-CEC on the Blu-Ray player fixed the issue. The Yamaha receiver already had HDMI Control disabled, and all the other HDMI devices appeared to have HDMI-CEC disabled or not supported.
In my case, the symptoms of the issue were that I would see the correct picture for a second on power up, then the picture would go away. For the Blu-Ray HDMI input selected on the receiver, I would see a solid purple screen and a blank screen for the rest of the inputs. Sometimes switching inputs fixed the issue, sometimes power cycling would fix it, but it was getting very annoying.
Dec 03, 2012 | Yamaha Audio Players & Recorders
Acer 5920g, nvidia 8600m gs. the problem is that when I connect hdmi cable from tv to laptop, laptop screen freezes, and tv screen display hdmi logo, but without picture, If I disconnect cable, tv starts...
check windows optional updates....or try booting up with tv already linked....ooo check the display settings for dpi and Hz some tvs wont go above 60Hz
Nov 19, 2012 | Computers & Internet
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
PS3 Connection problem with this particular tv model.
connect PS3 to Tv with RCA cables (white,red,yellow) go to display settings change to HDMI, Tv should go black remove RCA cables and connect with HDMI.
Jan 10, 2018 | Samsung LE22B450 22 in. HD-Ready LCD TV
I am trying to hook up my ps3 but it says change resolution source
make sure everything is plugged in correctly. also make sure that the input/source of your tv is correct. If all these don't work, then: 1. unplug both the tv and the ps3 2. plug them both back in 3. turn the tv on first make sure it is on the right hdmi source. 4. turn the ps3 on by holding down the power button for about 10 seconds until it beeps.
the ps3 start screen should show up now.
May 28, 2011 | Philips 32PFL3505D 32 in LCD TV
I cant play my ps3 on my sanyo tv
May 27, 2011 | Televison & Video
Tv will not turn on. Flashes 10 times. If we unplug/plug it basck in several times we can eventualy get it to work. Seems to be getting worse every day.
You need to replace the power supply, PN: ETX2MM704MGH. This 10 flash failure is common. I hope this was helpful, best wishes.
May 12, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
VL320m will not connect with my computer via HDMI after power outage?!?!? Can anyone help me please. Tryed unplugging for 5 min that didnt work. updated Bios that didnt work. What could have happened?
Well, it could be one of a few thing, first, maybe you have simply "Lost" your Video Drivers, install your Video and HDMI drivers again, ensure you set it all up correctly, and have the PC configured for Multiple desktop, and the screen resolution and Format are correct. Also the correct External input is selected (HDMI). Now On the TV, you should also unplug the set to "Rest" anything that may have gone awry, now re-set up the TV again, after you are sure all is working, then with everything OFF, plug it all up, and in. Turn ON the TV, and select the HDMI input, Now startup the PC, it should detect the TV and you should display a picture. If you don't get a picture power off tv and try again, check all once more,if you are still no go then I suspect the the TMDS transmitter has had an overcurrent situation,often caused by a power outage and or spike, surge, if left plugged in when power was reconnected. In this case, you will need to get it repaired, or get a service manual, and maybe have a go yourself, hopefully it will not come to that.
May 14, 2010 | Vizio VL320M 32 in. HDTV LCD TV
It green screens after 10 mins
Are you using hdmi cable. If so your hdtv needs to have it's hdmi port reset .First unplug everything even the TV and xbox. Then disconnect everything and unplug every thing from the wall outlets. Then plug the TV back in and hook everything back up. The HDTV even with the power off can have it's hdmi port bumped so you need to unplug it to reset the ports.
Thank you
May 09, 2010 | Microsoft Xbox 360 Console
Televison & Video Logo
Top Televison & Video Experts
