Question about Panasonic Televison & Video
14 blinking panasonic th-l32x30d led - Panasonic Televison & Video
  • 39 Answers
SOURCE: Panasonic Plasma TH-42PV500H goes blank on power up
RKUMAR-ALL BLINKING LEDS ARE DIAGNOSTIC CODES WHICH NEED TO BE COUNTED PER SEQUENCE AND REFERRENCED TO A PANASONIC CODE CHART,COUNT THE BLINK SEQUENC AND LET US KNOW.JOE TV
Posted on Dec 17, 2007
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-C42HD18 Blinking Power LED (7 times)
NEED SD OR SU OR SC BOARD REPLACED
Posted on Sep 21, 2009
SOURCE: my panasonic plasma tv has some error! the red led
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Posted on Oct 06, 2009
freelance-au
  • 131 Answers
SOURCE: my panasonic model #TH-50PX75U wont turn on, it
I would suspect faulty capacitors in your power supply, Take the back of and look on the power supply board for capacitors that have domed shaped tops, they may also have a brown liquid like substance leaking from them.
Replace these and this should cure your problem if it is capacitor related.
Posted on Mar 05, 2010
  • 380 Answers
SOURCE: panasonic model #TH-50PX75U wont turn on, it
Usually seven blinks indicates a Y sustain problem. Its either the Y sustain pcb and/or the buffer boards. I would highly recommend calling an authorized service center for this if you don't know what you are doing.
Posted on Mar 09, 2010
TH 42PV8H A MY TV POWER NOT ON RED LED 2 TIME BLINKS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Mar 16, 2016 | Panasonic TH-42PV8H 42 inch MultiSystem...
12 blinks on th-p42x20m
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 13, 2014 | Panasonic Viera TH-50PZ85U Plasma TV
PANASONIC TH-50PX75U PLASMA TV LED LIGHT BLINKING 10 TIMES
That is a power suuply problem,i have the same problem i looking for a solution to fix my or i gonna buy a new one,also new onw is spensive on ebay some people offer the repair service good look
Sep 03, 2012 | Panasonic TH-50PX75U Plasma HDTV
Panasonic model th42pz77u no pic, no sound, blinking red light ten times
9.2. Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
26
TH-42PZ77U:
There are different patterns for blinking light...
10 times indicate DG board problem - SUB 5V SOS, MAIN 3.3V SOS, DTV 9V SOS and Tuner Power SOS.
Aug 16, 2010 | Panasonic TH-42PZ77U TV
Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic Viera TH-50PZ85U Plasma TV
My panasonic plasma tv has some error! the red led bliks 7 times then pause and then 7 blinks again. what i can do? panasonic th-42pz70e
Sep 12, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic TH-42PZ700U Blinking Light Of Death
Panasonic sent a repairman out with the correct part for free, even though the unit was out of warranty. Call 800-524-1448 1 or 800-211-7262
Sep 08, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic pt-52lxc66 power light blinks
There are actually two red leds present on your tv and depending on which one is flashing is going to tell you what to replace. 3X on the Temp led will point to a faulty thermistor and you would want to replace this part. If the 3 red blinks are the lamp light than this is a error on the iris position and you would need to have the optical block replaced.
Josh
Feb 09, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Jan 08, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Televison & Video Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
