Cannot change channel on separate tv duolview decoder
Why wont some fee to air channels tune in I keep getting a message not supported
Sounds like your TV Needs a separate decoder box to receive the HD channels (free HD but with better decoder) some channels need a Paid for Interface card that plugs in the back and some are region sensitive.
Oct 13, 2016 | Televison & Video
Connecting Digital Decoder to Analogue TV.
The av channel is 0 and then you need to search on channel 0 as i mean tune into the channel
Sep 14, 2008 | Televison & Video
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
Hi, I have just shipped a SHARP LC-37AD1E tv over from the UK (where it worked fine!) It is one of the early models that has a separate media box. It has tuned in fine to the Australian channels BUT there...
No. The audio and video signal must be decoded first before you can connect it to the home theater system. Your Australian channels might be different from the UK's. Try a decoder box made for Australian stations.
Dec 04, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Our remote will not change channel and we can not change channel from the TV either. We have changed the battery and cleaned the front of the TV.
The tuner in the TV is bad. Try connecting a regular decoder box and tune that instead. Make sure your source is selected for the box.
Nov 03, 2010 | Samsung Televison & Video
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
May 17, 2010 | JVC LT-37E478 TV
Do I need to buy a digital converter box to watch tv on an outside antenna?
Yes, Even FreeView, requires a "Decoder" Box with an external Antenna attached, and the signal is fed from that, to the TV through the AV, External Inputs, ON TV, essentially making it a monitor, for the "Decoder" The Channels, Volume, are changed on the "Decoder".
Apr 14, 2010 | Durabrand DWT2704 TV
Why can't I tune in new channels from set top box through vcr?
Sounds like you are trying to receive the new Over The Air OTA, digital ATSC signals on a VCR that can only receive analog NTSC, which are not sent by any but low-power channels. Did you miss the change over last April, postponed from Feb, and featured on every TV channel when you could have obtained 1 or 2 $40 coupons toward ATSC-to-NTSC converter boxes. Try for more info, IIRC.
If you are speaking of cable TV then see your company. These may be digital Quadrature Amplitude Modulation QAM signals that only certain TVs can decode provided they are not encrypted. Locals are never encrypted. This is separate from the ATSC conversion.
Oct 04, 2009 | Quasar VHQ940 VHS VCR
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
