Question about Garden
My yard works 60-2090-8 grass trimmer has started to pull the line back into the spool while it is running,any thoughts on what might cause this.
I have taken the spools apart and cleaned them
    Top Expert:
  • Garden Master
  • 39,260 Answers
The trimmer is defective.
Posted on Aug 12, 2017
  • 313 Answers
SOURCE: Can't find spool replacement AF-150-04
not sure but .065 maybe
Posted on Jul 09, 2008
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
  • 246 Answers
SOURCE: can't find manual to 26ss mighty lite trimmer.
Hello jonandchima:
This is a Homelite Product.
You can Order a Manual from this Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information and Select "Need Manual" . Remember to Include the UT Numbers.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
SOURCE: Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
Posted on May 30, 2009
  • 6 Answers
SOURCE: at home depot I can purchase .065 line without the
It is fairly easy to restring trimmer. just follow the arrows on the spool.
Hope this helps
Tobaz
Posted on Jun 17, 2009
Put in replacement spool cutting great as usual went edge the head with spool of line wont turn went back to normal position spool will not spin to cut motor runs spool head not engaging how can I fix
pull the head completely off and make sure that the shaft is not broken, if not then line it back into the head slot and put back together and test it out, Tim
May 29, 2011 | Black & Decker 14" Grass Hog Xp...
How to respool the line on grasshog electric grass trimmer
The empty spool can be refilled with 30' of size .065" nylon line. Make sure you run the line in the direction of the arrow embossed on the spool.
Sep 06, 2010 | Black & Decker 14" Grass Hog Xp...
The line continually spools out. Used both rolls of line to trim my yard 1st time I used it.
Pull the line spool off and check to see if the line is on backward. There is an arrow showing the correct direction to wind. Good luck...Lee
Jun 11, 2010 | Black & Decker Black and Decker & Grass...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
How to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
How do you refill the string on the homelite electric, straigh shaft, 13 in Trimmer?
Is the sting the cutting line at the bottom of the trimmer? If it is pull the spool out. At the bottom of the spool there is an arrow pointing in the direction that the line should be wound. When you first put in the line be sure to place the cutting line in the grove (V shape) and then when you put enough line around the spool. Thread the end of the line thru the hole on the side of the spool. Slide the spool over the shaft of the trimmer and it will click in. When the line is short just tap the spool lightly on the grass and it will feed out more line.
Good Luck.
Jan 06, 2010 | Homelite Garden
Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
How can I remove the old spool kit from a grasshog xp1000? I have a new one to replace it but can't get the old one off.
After removing the screw, I had a heck of a time pulling off the old spool kit. I ended up running a rope through the holes that the cap clips into, stood on the rope and pulled up on the Grass Hog. Finally I managed to pull the old kit off. I managed to put the new one one, but I'm not 100% sure whether the cross-shaped piece at the bottom of the post is perfectly lined up with the new spool head. I was able to replace the screw and so far it seems ok.
Jun 04, 2009 | Black & Decker 14" Grass Hog Xp...
Don't know how to rethread the line
Breaking off is a normal process. Set the centre of your line in the spool and wind the two strands in to the Spool, thread and re assemble. C
May 27, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
