Question about Husqvarna Garden
Husqvarna GTH24V52LS plug is heavily fouled and oil is leaking onto muffler connection.
    Loyalty:
    Visited the website for 30 consecutive days.
  • Husqvarna Expert
  • 190 Answers
Running too rich, possibly clogged air filter, over filled with oil, engine breather blocked.
Posted on Aug 19, 2017
  • 160 Answers
SOURCE: muffler blowing white smoke
take it back the engine has a blown head gasket or cracked head all cost over 1200 to fix
Posted on Mar 15, 2009
  • 36 Answers
SOURCE: 1988 GM 4.3 V6 Using about 3 quarts of oil in 75 miles.
the intake gasket is your proublem it is very comman it lets oil into the cylinders and it burns the oil witch fouls ur plugs
Posted on Mar 31, 2009
  • 4088 Answers
SOURCE: Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Posted on Jul 08, 2009
baugh55grfmj
  • 225 Answers
SOURCE: My Husqvarna 350 does not oil the bar only leaks
Well try emptying all of the fluids, cleaning it out with carb cleaner then high pressure air. Maybe debris caught in there.
Posted on Dec 29, 2009
SOURCE: oil fouling the spark plug but compression is fine
If you are telling the compression it fine i advice you to to put new spark plugs then see what it gives,then you will know what step to take after ,hope that help you and solve it.
Posted on Jan 20, 2010
Husqvarna LGT2654 leaking oil around the muffler
replace the gasket
tighten the muffler bolts
replace the muffler
Jun 19, 2017 | Husqvarna Garden
Our Husqvarna YTH2148 mower has been in the shop twice and we can't figure out what's causing black, sooty fouling of the spark plugs.
Hi, change the engine oil. It has become contaminated with fuel. Also fit an inline fuel tap and turn it off whenever the mower is not in use. Basically the carby has leaked fuel into the engine oil, the engine then draws the fuel vapour from the oil through the crankcase vent into the carby creating the problem you have. Regards Phil.
Jun 03, 2012 | Husqvarna Garden
Muffler turn red hot
You need to change the spark plug. Your mower is probably misfiring and your gas is burning in the muffler. The spark plug may have been fouled by a host of things including dirty fuel.
Sep 11, 2011 | Husqvarna Garden
My 1995 Saturn has on oil leak-it looks to be near the right-side CV-Axle. Also it lacks power. I cleaned the sparkplugs recently and it was running fine again, but when I put about 4 quarts of oil in,...
IF OIL LEAK RED IN COLOR.TRANSAXLE AXLE OIL SEAL LEAKING.HOW MUCH OIL PUTTING IN THE ENGINE TOO MUCH OIL FOUL OUT SPARK PLUGS.YOUR CAR USE 4 QUARTS OF OIL PLUS NEW FILTER.
Mar 22, 2011 | 1995 Saturn Sl
Husqvarna 141 oil leak
This model was notorious for leaking oil, there were a number of issues, one of which was the fit of the seals around the oil pump assembly, the inner and outer sealing was replaced by a single piece seal to make it better part no. 545037101, there were also issues with the oil tank itself, the outer half was friction welded on to the inner, some of the seams were not very good and oil would leak from there, in very extreme cases the muffler would leak exhaust gas onto the top of the tank and melt a hole in the tank.
Feb 26, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I start my chainsaw and about 10 seconds after its started it starts smokeing and bogging out,how do i fix that
Check the oil mixture sounds like you have to much oil in gas.try mixing it at 32:1.If it has tomuch oil it,s bogging down because it,s fouling out the plug.
Dec 06, 2010 | Poulan 18" Wild Thing Chainsaw
Engine will not start.Has good spark and get gas.
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 23, 2010 | Husqvarna 28cc Gas Line Trimmer
It's flooding how can i fix it
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Overfuel or 'rich' condition
Basics to check:
b) is there spark
3) Check Air filter for fuel saturation
4) Allow engine to run for 5 minutes remove to excess fuel from muffler
5) Fuel mixture ratio: Make sure the oil mix is per your manufactures recommendations
6) If after the above the engine is still smoking and blubbering:
Adjust carb mixture screws to a 'less rich' setting
*NOTE: only move mixture screws 1/8 of a turn at a time,
and try operation before any more adjustment
Nov 26, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
I have an Echo Backpack Blower PB46-LN that is leaking black oil out of the muffler, its easier to start when its cold but when its hot it difficult to start, also I dont even need to prime it to get it to...
This senerio is an 'over-rich' condition, most often caused by an improper fuel/oil ratio mix, and the 'exhaust screen' or 'spark arrestor' on the outlet of the muffler is plugged. Cleaning the screen may be all that is needed to correct the problem. **Make sure this screen is clean, and operate engine for at least 5 minutes before making any of the suggested adjustments below.
Basics to check:
b) is there spark
Basics to check:
b) is there spark
4) Allow engine to run for 5 minutes to excess fuel from muffler
Nov 12, 2009 | Echo Garden
Garden Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
