My Roland Street Cube's input jack has fallen inside the body of the amp. How do I fix it?
I'm not too great at fixing stuff like this, but I'm a street musician and my livelihood kind of depends on this amp...
    Top Expert:
  • Audio Player... Master
  • 40,436 Answers
You will have to disassemble the amp to get access. You may find that provisions for retaining the jack are weak or broken, in which case some glue may be required.
Posted on Aug 12, 2017
3 Suggested Answers
  • 5 Answers
SOURCE: My explorer is squeaking and creaking LOUD, just
have your brake pads checked,soounds like yours are worn out.
Posted on Mar 08, 2011
  • 1455 Answers
SOURCE: Good Morning. My name is Mohammad
Dude, this is not a donation site, only a repair advice site. You need to look elsewhere.
Posted on May 15, 2011
My Roland Street cube amplifier has a bad speaker- where can I find a replacement speaker?
Rubber cement is an excellent for minor speaker cone damage but if you feel that a replacement is required, try MCM Electronics online. They carry lots-o-speaker replacements. Be sure to match wattage and impedance (ohms) of the speaker though as these are important spec's.
May 21, 2014 | Roland Cube-st Battery Powered Amp Cube...
My roland cube street starts making this really weird loud noise
Hi, Quick Check. Very often the input socket which is soldered directly to the circuit board, will have a broken solder joint. This is common on a very large amount of equipment. Try waggling the plug about and seeing if the noise comes and goes.
Easy fix, re-solder joint. Permanent fix, connect socket to board with flying leads, or fix socket to board with hot glue or epoxy resin.
All the best, Chris the Fader.
Mar 23, 2013 | Roland CUBE Street Amp Combo
Roland cube street water damage repair
What part of it got wet will determine the course of action.
If the whole unit were submerged, the unit may prove more time consuming to try to fix than to locate a used one. However, I have salvaged imersed laptops before. the procedure is not much different- make sure the unit is as dry as you can possibly make by blowing a fan on it for an extended period of time.- Days.
Once dried, use some contact cleaner on the jack contacts and interupts, any manual control and any switch.
You can then apply power. If nothing lights up, check and replace fuses as needed. Also check the power supply board for failed caps or rectifiers.
Once the power supply is known to be functional, systematically check the LCD display and the aspects of the amp that it controls. This board will be the most vulnerable and most likely to be the source of most issues you will encountr.
If the display survived intact, and amp does nto work, apply a signal to the inputs and trace the signal through the amp with a set of headphones set up with test prods. The problem will be where the signal stops.
Apr 26, 2012 | Roland CUBE Street Amp Combo
Roland Micro Cube Amp fuse blew out. How do you fix it?
have a look here:
although it doesn't mention the fuse you will probably find it. Sometimes there is a fuse access on the outer case.
Jan 11, 2012 | Roland Micro Cube Battery Powered Amp...
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
Input jack fell inside
Yes, the jack MAY actually be broken. It will need to be serviced. Run cables through the handle to avoid plugs from being yanked sideways and breaking the jacks.
Aug 23, 2011 | Roland Cube-20x (20w 8" Modeling Guitar...
Hello my roland street cube won't power on, either with dc or batteries....adapter working .could a fuse be blown inside circuitboard? thanks
That is the first thing to check. They are most likely inside the circuit board. Remember to replace them with the same voltage and amperage ratings.
Feb 13, 2011 | Roland Cube-st Battery Powered Amp Cube...
Amplifier not working
The Cube 60 is a guitar amp, Often these problems are due to a damaged inout jack on the unit. People trip over the guitar cable and the cord gets yanked sideways and breaks the internal parts of the jack. Sometimes circuit boards are cracked.
ALWAYS run your cord through the handle or restrain it should the cord be yanked.
The problem with your unit is internal and it will need to be opened and trouble shooting done.
Dec 15, 2009 | Music
Guitar amp signal interference.
Mine did that. Found out it was the input jacks
Apr 29, 2017 | Roland Music
29 people viewed this question
