Question about GE Refrigerators
My ge frenchdoor refrigerator climate control drawer won't pull all the way out on the left side gets stuck.
fridgetech
  • 473 Answers
SOURCE: GE monorgram frost in the ice shute
Sounds like the ice door in the dispenser isn't closing properly or all the way which lets warm air in condensates then freezes.
Posted on Oct 22, 2007
Bgillespie
  • 89 Answers
SOURCE: GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Posted on Dec 17, 2007
Master_Tech
  • 770 Answers
SOURCE: Maytag Frenchdoor w/freezer drawer - drawer sticks
you will need to remove the front and get to the slides clean them off and buy a low temp silcone to apply to tem do not buy grease apply it and work it in the problem will go away
Posted on Jan 24, 2008
  • 184 Answers
SOURCE: GE monogram side by side built in refrigerator: fan behin Climate control drawer makes noise when it starts
IS THE NOISE SOMETHING HITTING THE FAN BLADE?
CHECK THE FAN ASSEMBLY BY REMOVING THE BACK PANEL IN THE FREEZER COMPARTMENT.
NORMAL NOISES IN THE UNIT ARE A GURGLING NOISE OR THE SOUND OF RUNNING WATER OR HISSING. THIS IS DUE TO THE FREON BEING PUSHED THROUGH THE SYSTEM AS THE COMPRESSOR RUNS. POPPING OR SNAPPING CAN OCCUR WHEN THE COILS IN THE FREEZER MOVE DUE TO A CHANGE OF TEMPERATURE.
Posted on Apr 08, 2008
SOURCE: Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Posted on Jun 16, 2008
My GE climate control drawer always has water in the pan . I wipe it out and when I return there is always water on the bottom.
Which model do you have? Its easier to tell you when I can get the information of the unit. I can guess, obstructed drain to the evaporator in the fresh food section, or a leaking water tank, but not sure as all units are not built the same. Thanks
Apr 11, 2016 | GE Monogram Side by Side Refrigerator
GE monogram buildin refrigerator - climate control drawer cannot hold the temperature as set for meat. It always shows at 47F.
sounds like the damper door down there is not opening also the fan down may not be coming on to bring temp down to 32.
Sep 17, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Maytag climate control drawer fan is not running.
Refer your inquiry directly to Maytag or an appliance parts supplier.
Jun 28, 2014 | Maytag MZD2766GES Side by Side...
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
The climate control drawers keep running and switching from thaw to chill and we cannot get the climate control drawer to turn off
scroll down and look into the other responses,. there may be some similar one to yours where you will find a better answer than I can give you now.
Best regards,
Ck
Dec 03, 2011 | GE Refrigerators
Climate control drawer is 20 degrees, freezes everything,
on the bottom part of refrigerator right wall , theres a thermister, i bet is faulty
Jul 11, 2009 | GE Monogram® ZISS420DMSS Side by Side...
MSD2758GEW Climate Zone Drawers
This fridge is garbage. Fixed ours 14 times in 6 years. WILL NEVER BUY ANOTHER MAYTAG ANYTHING AGAIN!!!! CLIMATE ZONE TECHNOLOGY DRAWERS NEVER DID WORK CORRECTLY....EVER.
Jan 31, 2009 | Maytag MSD2758GEW
Apr 08, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Dec 17, 2007 | GE Profile PFS22 33" Artica French Door...
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
