Question about NEC Televison & Video
I need a universeal remote to my nec mts db - NEC Televison & Video
    Top Expert:
  • NEC Master
  • 43,947 Answers
Fixya does not sell replacement remote controls. The best resource is on line.
Posted on Aug 12, 2017
Maanita
  • 1142 Answers
SOURCE: Universal Remote control code on Sharp 13H-M60
Try this
complete guide to your remote solution
Posted on May 20, 2008
aprmaejun
  • 97 Answers
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 20, 2008
  • 4 Answers
SOURCE: Phillips Universal - need code for NEC NDV 28 DVD player.
I have a Phillips 5-in-1 Universal Remote (model MRU3500), and I have my code list booklet. There is only one (1) code given for a Nec brand Dvd player: 0142. Hope this helps you.
Posted on Oct 14, 2008
  • 1335 Answers
SOURCE: i digital universal remote RM-810 - need code for
Try 184 for the NEC TV.
Please rate this solution. Thanks.
Posted on Sep 02, 2010
gopakumarg43
  • 75404 Answers
SOURCE: Need to find code for
Hello
Aiwa TV is not lited on Jumbo Universal Remote codes. Anyway try out with these codes. Sometimes may help you.
Three digit codes for Aiwa TV with universal remote are:
195/ 196
Four digit codes for Aiwa TV with universal remote are:
0195 0196 0227 0269
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your TV with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
OK
Posted on Jan 27, 2011
Need a universal remote control code for a mts stereo tv
0029,0022,0026 are the codes to check. If you wish to get more codes and other details.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
It has setup code list, and setup procedure to many popular brand remote controls.
Jan 02, 2014 | One For All URC-3021 Remote Control
I cannot enter fuction programming on viper 5501
You're going about all wrong. ALL the power wires need to be connected.
The MTS programmimg is not done through the remote, it's done WITH the remote. Open your instructions; Turn ignition on then off, press and hold programming button on antenna untill the LED flashes three times, release programming button. Now, press and release the programming button one time then press and hold. (This the transmission option) Press the unlock on the remote. The LED should flash two times indicating that the system is now in automatic transmission. Turn the ignition on to exit programming.
Dec 17, 2012 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
I digital universal remote RM-810 - need code for
May 28, 2010 | Universal Remote Control Remote Control
I have an old nec croma vision tv and have lost the remote.I have a spare panasonic remote and want to no the code so i can use the remote with the tv
The remote for Panasonic TV cannot be used to control your NEC TV. For this you need a programmable remote control.
For example visit this site to know more about Universal Remote control. The UniversalRemote can be programmed to control TV, DVD etc. The procedure is givenin the accompanying manual.
If you do not want to invest in a universal remote then visit this site to purchase an NEC replacement remote.
Please try to understand that you cannot simply use any brand of remote to control any other brand of TV; only a universal remote (or a replacement) will help.
Thank you.
Oct 18, 2009 | Panasonic Televison & Video
Nec tv codes for comcast universal temote
You may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Dec 17, 2017 | ViewSonic N3251w 32 in. LCD HDTV
Oct 09, 2008 | Philips 5-Device Universal Learning Remote...
Can't turn off SAP/MTS without remote
Dynatron MR 110 available at various sites including Amazon.
Aug 01, 2008 | Sharp 20H-S60 TV
Sanyo MTS TV
Hello
Most universal remotes should have a TV/Video button. Look carefully on the remote. Or get another brand remote.
Also depending on your Sanyo model there may be a TV/Video switch on the front of the set. Look for a possible small cover along the bottom.
Feb 26, 2008 | Televison & Video
Televison & Video Logo
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
