SOURCE: Dell touchpad icon missing
'Inactive icons' in the System Tray next to the time display do not display using the defaults in XP. To change this, right click over the Taskbar and choose Properties. Once you are in the Primary property page unselect "hide inactive icons." This may require you to log off or even reboot to affect this change.
Still, to get to the property pages for your Touch pad you want to enter Control Panel and then Mouse. Inside the Mouse property pages for control panel you'll see a property tab for the glide pad. Make your desired setting and then reboot. As you may already know, the scrolling function of the glide pad is accessed by drawing a finger down the far right hand side of the glide pad surface.
Hope this has helped and fixed ya.
Worldvet
SOURCE: data transfer
sir i dont know laymans terms but in english i can explain to you on how to transfer your videos to your computer.
SOURCE: desktop icons and taskbars not appearing in vista
Can you hit Ctrl-Alt-Delete? If you can, choose the Applications tab, then choose File > New Task (Run). Type "explorer" (without the quotes) and hit ENTER. Something is loading up on your machine and is using up all of your system resources, possible virus or spyware.
SOURCE: missing task bar and icons
assuming that u r using ram(s) more than 512mb(recommened) or atleast 256mb..and hv enough free hdd space..
i don't know which version of os u r using..however if u r using win xp..press 'ctrl+alt+del' at a time..task manager will open..click on the file menu..click 'new task (run)'..type 'explorer'..click ok or press enter..
now without wasing time..install an updated n licensed antivirus (i prefer avg/kaspersky)..go for a through system scan..
try increase the size of virtual memory: start menu->run->type 'sysdm.cpl'->click 'advanced'->click on the 'settings' submit button under 'performance'->click 'advanced' tab->here u'll find 'virtual memory', click 'change'->select c: from the list->type the 'initial size': 1440 and maximum size: '2880'->click 'set'->ok->ok..donot restart the pc now..hv aglance ovr the software strength..look for startup items (the programsloaded during startup)..download n install n run 'Statup ControlPanel'..
http://www.pcworld.com/downloads/file/fid,7976-order,4-c,desktop/description.html
andmicrosoft kb890830..remove the unnecessary boot item(s) or do post me acomplete list of startup item that the Startup CPL is showing (in itzevery tab), i'll guide u..
also u may use 'Advanced System Care Pro' to fix all at a time..now restart the pc..
seek professional supervision of ur system admin/vendor....
