Question about Super Video Game Consoles & Games
I have 500gb super slim ps3 and please tell me how to jailbreak or intstall multiman ?
    New Friend:
    Problem Solver:
  • 7 Answers
In the Brazilian "Jailbreak", it seems the PS3 NOR is dumped to a memory card. Reading/Writing Data from a PS3 that has the right games "activated" on it seems to be the technique that has been used by hackers in Brazil to Jailbreak the PS3. Videos have been showcasing the use of a Raspberry PI and free software JAISPI to perform the dump. Note that it is recommended that you do not try to reproduce this unless you know exactly what you're doing.
Posted on Aug 12, 2017
4 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: Hi there, I want to
Follow the below procedures if the hard disk of your PS3 is defective;
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
I hope this helps...
Regards.
Posted on May 04, 2011
SOURCE: ps3 super slim comes on the goes off
sounds like the video card has raised from the motherboard and needs to be re-seated(reballing).. look up video reballing with paint heat gun $25 home depot.. electronic store like fry's for thermo heat sink paste $10.. (do not use radio shack paste to wet).. you may want to get these items for yourself cause this issue re-occurs about 3-9 months with some units
Posted on Dec 17, 2013
sandraspa25513
  • 180 Answers
SOURCE: How to fix super slim ps3 not showing video
Verify that you plugged video pin
Posted on Aug 09, 2016
My disc is stuck how i get it out
Bobby, it depends on the model of your system. There are different ways to remove the disk with each type of PS3. For example, the older PS3 (FAT) that uses the touch sensitive power and eject buttons, have a slightly different method than some of the newer models like the slim, or the super slim. Obviously, the "Super Slim" being the only exception in this case, because it has the old style CD tray like the PS1 that slides open from the top. I will give you a link to how to manually remove the disk. Again, if one way doesn't work, try another. ^^ Good luck.
How to remove stuck discs in your ps3 first generation
Dec 02, 2015 | Sony Playstation 3 (PS3) Console
My ps3 slim second generation is showing me red screen wen i try to update with ofw
Well, Jailbreaks are often very buggy. If you don't want issues like this to happen, then update only the latest firmware from SONY and don't MOD your system. I've seen several systems "brick" from MODS. Good luck, and hope this helps. ^^
Oct 29, 2015 | Sony Playstation 3 (PS3) Console
My PS3 has a major fault and I don't know what is causing it
Mark, as much as I'd love to talk up about the PS3 system, I have heard of a major concern. With the latest iteration of the SONY PS3 system, affectionately named "Super Slim", it's no secret that SONY cut some corners in the production of the new system. Mainly, the redesign eliminated the blue-ray disk drive mechanism from all previous versions of the PS3, resulting in a very PS1 like configuration. (Very simple opening door). In doing so, the cost of manufacturing was cut almost in half. From my personal experiences with the "Slim" and "Super Slime" I can tell you there are marked differences in performance. The software is solid, but when I play COD Advanced Warfare on my "Slim" I notice the game plays smoother than the "SS", and the disk spins much faster and louder than the "Slim". If I had to guess, and this is from several systems, the Blue-ray drive is spinning up, then causing the cpu to overheat(Another much blogged problem with the "SS"), resulting in a diode failure that shuts down the system. If it's still under warranty, take it back for a new one. If not, you're going to have to send it in for and "Out-of-Warranty" service that may be pricey. God luck, and hope this helps.
Sep 27, 2015 | Sony Playstation 3 (PS3) Console
Por que me corta el wifi en ps3 super slim 500gb y cell y tablet por cortos tiempos
Conexi?n ADSL con filtros de ADSL. ¿Ocurre si alguien llama a la l?nea telef?nica? Podr?a ser defectuoso filtro ADSL cayendo conexi?n a internet.
DSL connection with ADSL Filters. Does it occur if someone rings into phone line ? Could be faulty ADSL Filter dropping connection to internet .
Jul 17, 2014 | NetGear R6300 WiFi Router
When soda is spilled in ps3 game system what to do
I suggest taking it apart and cleaning the sticky spots with a Q-tip and Isopropyl alcohol.
Here are some links on showing you how to take you system apart.
PS3: http://www.ifixit.com/Teardown/PlayStation+3+Teardown/1260/1
PS3 Slim: http://www.ifixit.com/Teardown/PlayStation+3+Slim+Teardown/1121/1
PS3 Super Slim: http://www.ifixit.com/Teardown/PlayStation+3+Super+Slim+Teardown/10670/1
Jul 17, 2013 | Sony Playstation 3 (PS3) Console
How to install a PS3 Slim HDD into an old PS3
This is rather a good question, a slim uses a mini connector witch will need to be adapted out before it is connected, then you talking about firmware to marry it to the system witch can be hard to find, I would say if you want to try this www.videogamerepairs.com would be your best bet.
please do not forget to rate.
Oct 11, 2011 | Sony PlayStation® 3 (80GB) Console
Hey, guys. Just bought a PS3 Slim 320GB. Want to know if I can swap the hard drive for something bigger, like 500GB or 1TB. If I can, will I need to do some software mods, or is it just like plug-n-play?...
chrisff60
To upgrade your hard drive you will not need to mode the system. I know the system should support the 500gb drive. As for the 1tb drive it may work but it depends if the system has support for a 1tb drive. Sony may have not added support for 1tb drives to the PS3. The link below will show you how to remove the hard drive.
http://www.fixya.com/support/r6324974-remove_hard_drive_playstation_3_slim
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 27, 2011 | Sony Playstation 3 Slim Console
Having trouble hard drive in ps3slim
Wiredextreme.com can fix your YLoD for 86 dollars and you can buy up to a 4 year warranty that covers everything on the PS3.
I suggest returning the slim and sending in the 60GB
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
26 people viewed this question
Top Super Video Game Consoles & Games Experts
blevinslance
blevinslance
Eric Sutherland
rhodesworks
Are you a Super Video Game Console and Game Expert? Answer questions, earn points and help others
