Question about Bobcat Garden
Why won't the right side of my bobcat work - Bobcat Garden
    Champion:
    Scholar:
  • 239 Answers
I would bet on a bad hydraulic flow regulator.
Posted on Aug 12, 2017
My bobcat 843 stopped pulling itself on the right side. Neither forward or reverse work. It acts like it wants to but won’t. Any ideas as to what it is and how to fix it??
broken motor drive shaft
broken shear in in drive shaft gear
broken drive chain for that side
faulty control valve assembly for that side
Dec 08, 2017 | Miscellaneous
1998 bobcat skid steer 763 has a surge problem
on a 1998 bobcat 763 y
There adjuster bolts on either side of the control levers. To access these you must focuse. Your attention to the bottom. Of control......turning the adjusters left or right will
Excellerate or decrease the drive speed.of left or right traxs or tire's
Feb 11, 2017 | Sewing Machines
How do i fix my bobcat 825 skidsteers hydraulics ? the right steering leaver works fine but the left does very little to nothing.
basically there are 2 points of control
1---is the control valve for that side which may not be opening the system
2--- the drive motor for that side which may be passing excessive oil and not turning
for the lift action to be slow indicates excessive pressure leakage in that circuit
early units had lever action to the control valves where as later units use electronic controls from joysticks to operate the valves
If this is your type of machine, I would be looking at faulty electronic control mechanisms or corroded wires and contacts
Dec 15, 2015 | Bobcat Garden
How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Sep 23, 2015 | Toys
My hand controls won't work on my bobcat 320
look at operator console on top right side , if parking brake light is on it wont do anything , if that's ok id look at occupant seat switch and lap bar switch , one of these must be open
Sep 17, 2015 | Bobcat Garden
There is a window on the right side, which I believe is the window to check hydraulic fluid, where do I put it in?
Hi Christine,
Have you thought about consulting the user manual? If you've lost it look online. Search for ".bobcat *** user manual" where *** = your model number. You'll get several good hits including
Slideshare net and. http://bobcatservicemanual.wordpress/
Jul 24, 2015 | Bobcat 773
Where do I find the fuses on a bobcat 553
Should be in the engine compartment on the right side lower next to the bottom door hinge. There are two of them in plastic covers, you will see the wiring harness going into the back of them. The relays are above battery.
Dec 30, 2014 | Bobcat Welding Tools
Bobcat 753 arms wont move up or down.lights flashing on bix box for valve .have replaced valve on the right side below seat but same problem no movement in arms could it be the sensor switch on the s
if safety bar sw was defective then unit wont move fwd or backwrd . and park brk would not disengauge , no sounds as if you got a defective block pressure sensor for arms ckt
bobcat dealer service should have code scanner for this, would be faster less expensive than just changing parts to find cause
Oct 02, 2014 | Bobcat 773
My 1993 compact bobcat skidsteer won't start, it just stopped running and won't start, I have tried starting fluid and still nothing?
Could be engine speed sensor. All fuses need to be checked. Any smoke when cranking? Any fault codes? A bad fuel solenoid could cause no start if fuel is good.
Sep 09, 2012 | RTO Construction Bobcat by Woody Click
Battery location.......dahhhhhhhhhh
Hi Louis, the battery sits on the bottom of the unit, just inside the rear right side service door.
if you were to look at the machine from the back, it would be located right in the middle on the bottom of the unit.
Jun 24, 2010 | Bobcat Miller 225 Welder Generator 907209...
Garden Logo
35 people viewed this question
Top Bobcat Garden Experts
Daryl Gleaton
Dan Apthorp
Jim flowers
Jim flowers
Are you a Bobcat Garden Expert? Answer questions, earn points and help others
