Question about Husqvarna Garden
Fitting steering spring and connectors on husqvarna rider
    Loyalty:
    Visited the website for 30 consecutive days.
  • Husqvarna Expert
  • 201 Answers
Special tools are required to stretch the steering spring, not to be taken on lightly if you have never done one.
Posted on Aug 19, 2017
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 136 chain brake handle spring.
You can get an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
I don't think this has the detail you need.
If it were me I'd visit my friendly neighborhood Husky chainsaw seller (not Big Box Store) and ask to look at the clutch cover with the brake installed (take a camera). I'd probably ask for a quote for their repair too. HTH
Lou
Your model is no longer sold. The seller will know what model replaced it and may be willing to explain the repair procedure for your saw you. Take the cover and loose parts with you.
Posted on Sep 07, 2009
moe_2782
  • 443 Answers
SOURCE: Does somebody know the colour code from Husqvarna Rider mower deck? Grey?????
I think it is in hex ( 494841 ) or (444 33d)in hexadecimal
Posted on Jul 04, 2014
REMOVAL OF STEERING WHEEL ON PAJERO 1999 HOW IS IT DONE
IF YOU HAVE ANY DOUBTS ABOUT THIS, HAVE IT DONE BY A GARAGE THAT IS USED TO HANDLING AIRBAGS.
#1. center the steering wheel and remove the ignition key to lock the wheel and column. DO NOT undo it until the steering wheel is replaced. If the column moves the clock spring can be easily broken.
#2: Locate the airbag controller, and disconnect the yellow connector and fit a shorting pin. This is to ensure that the airbag does not explode.
#3. pull of the horn button, which exposes the airbag and (fragile and expensive) clock spring assembly.
#4. Remove the nut on the column. You may need a puller device if hitting the steering wheel does not release it.
Feb 18, 2015 | Mitsubishi Pajero Cars & Trucks
How to fit a starter motor on a Husqvarna rider pro 15 ?
when your fiting it to the motor you will need turm the motor with your hand to get it to seat for the bolts to fit in
Jul 26, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Weed eater one drive chain comes off
The problem with the chain Is the tensioner. There is not much the small spring can do. You may try to add tension to the chain but, not a good design.
Jul 20, 2014 | Husqvarna WE261 960220007 26 190CC Weed...
Jul 03, 2014 | Husqvarna Garden
Husqvarna 346 xp. Changed brake band and spring, how do i reassemble with chain brake "off" so will fit back over clutch?
Re assemble the brake in the actuated mode, remove the clutch and sprocket from the saw, now fit the brake back to the saw and use the hand guard to load the brake, now re fit the clutch and sprocket
Apr 14, 2011 | Husqvarna Garden
Husqvarna 54 inch rider, fairly new, bought used. Deck will not fully lower or raise even after levelling per manual. Are 54 in decks more susceptible to this type issue?
the Rake adjustment is critical on this mower make sure the front to back is within 1/4 inch of each other with front being the lower this adjustment is on the front if its a single rod the bracket that attaches it to steering axle is probably sprung back this happens from running the mower into something with the deck.
Dec 02, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Do all sears snow blowers fit on a craftsman lawn mower
yes and they will also fit ayp, husqvarna and poulan riders as they are all built by the same mfg. just be sure to get the snow blower that is for your modle tractor
Nov 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
We have a Husqvarna Rider, model YTH180. It's
whats rough the motor if so you could have bad gas or bad plugs or somethin els you may need to get that to a shop
Sep 27, 2009 | Husqvarna Garden
Tomtom rider 1 not charging when on bike
TOMTOM are VERY aware of this problem. but deny it is an issue!
I had the same problem, they sent me a new shoe after weeks of emails. I told them that the shoe is not the problem, it's the connector on the back of the TT1. Because of the springloaded pins fitted to the shoe and the poor quality connectors on the TT the normal vibration on a motorcycle causes the pins to wear holes in the connectors on the TT causing intermittant connection.
As the cost of repairing or replacing these connectors is very high and there are a large number of units that would require this repair TT are ignoring it.
I'm now looking at a way of bypassing the connector altogether.
A temporary solution appears to be to smear the contacts on the back of the rider with a little petroleum grease or WD40 - seems to work for a couple of weeks at a time.
Sep 01, 2008 | Tomtom RIDER GPS Devices
Garden Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
