Question about Panasonic Office Equipment & Supplies
Panasonic dp 180 error e01-13 check scanner unit
SOURCE: PANASONIC DP-180 PROBLEM IS EO4-01 CODE
panasonic dp-180; how to scan
Posted on Apr 25, 2009
  • 990 Answers
SOURCE: Where's the fuser unit on a Panasonic DP 3000
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
Posted on May 16, 2009
goodgold
  • 389 Answers
SOURCE: Panasonic DP-C262 Copier
This costs around $300US, only you quite do not follow to change whole block. He wholly can be repaired, moreover if it is indicated fault of the stove, that this means that came out of building lamp,or thermo fuze or thermistor, as far back as stove change the rubber gross and gross teflon, but absolutely not without fall you will need its change. Return in service, this wholly part fault. Good luck
Posted on Sep 21, 2009
tech435
  • 284 Answers
SOURCE: Error Message Reads: Check Scanner Unit E01-31
try checking the scanner cable . look through the glass back right . you will see a usb cable.. check both ends.. if there connected properly and you still get the error.. you need to replace the whole scanner unit
Posted on Oct 23, 2009
  • 95 Answers
SOURCE: How do I change ip address on panasonic dp-180
Please follow the instruction indicated on the user manual for this product.
Here's the link for the manual.
Hope this helps . . .
Posted on Apr 04, 2010
Error E01-01 CHECK SCANNER UNIT
the scanner beam of the machine is damage it has to be replaced before it will work properly.this can be done by a technician with the necessary tools to uncouple.
Feb 07, 2011 | Panasonic DP-8020E Black and White Copier
Plz help me how can i download fax and scanner drive for panasonic dp 180. thanks and regards junais
Panasonic DP-180 Drivers and Software can be download from the official support site.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 21, 2010 | Office Equipment & Supplies
ERROR CODE READS CHECK SCANNER UNIT, E01-01 IS THERE ANYTHING THAT I CAN DO, OR DO I NEED TO WAIT UNTIL MONDAY FOR A SERVICE CALL? THANKS FOR YOUR INFORMATION.
ERROR CODE READS CHECK SCANNER UNIT, E01-01 IS THERE ANYTHING THAT I CAN DO, OR DO I NEED TO WAIT UNTIL SUNDAY FOR A SERVICE CALL? THANKS FOR YOUR INFORMATION.
Dec 04, 2010 | Panasonic Workio DP-190 Multifunction...
I need printer drivers for my panasonic dp 180 - i have windows 7/32 bit
you can go to this website and download the beta version
http://panasonic.net/pcc/support/mfp/dp-180/pdl/download.html#01-6
hope this help
Sep 07, 2010 | Panasonic WORKiO DP-1520P All-In-One Laser...
Getting error j43 on workio 190, but there is no paper jam
yep
it is common error for dp-180/190.
and the usual cause of that are worn out 2 bushings of heat roller
what you can do with that is to clean the fuser unit esp. the bushings of heat roller.
well off course the safest way is to replace the whole fusing unit.
that's it. :)
Feb 08, 2010 | Panasonic Workio DP-190 Multifunction...
PANASONIC WORKIO 180, good morning, my printer
Thank you very much for requist, First time follow my tips.this problem is carry on Fuser unite.heater lamp fuse or fuse is burning,change thermostate.
Dec 09, 2009 | Panasonic Workio DP-190 Multifunction...
Error Code E07-12
HEllo sir; Try to make a copy without the cover,see the exposure lamp is on or not if not check the thermo fuse and exposure lamp.
May 23, 2009 | Panasonic Office Equipment & Supplies
Panasonic DP 180 - will not print faxes
you need to do an all job clear in fax mode. leave me a msg and i will try to help
Oct 04, 2008 | Panasonic Workio DP-190 Multifunction...
46 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
