Question about Janome Sewing Machines
Janome jfs1817 right knob came loose. how do i put it back? there are a clip and srew. am i missing a shaft?
4 Suggested Answers
  • 71 Answers
SOURCE: Retaining clip?
You may have a clip that is not seating properly in the groove. Try to push the clip into the groove, work your way around the splines. You are just checking to see that it does not stick anywhere in the groove keeping it from compressing. If you replaced the clip yourself it may be spread too far open causing it to hang on the edge of the gear in the transaxle. If so remove the clip and compress it with a pair of pliers so that it is now smaller than the inside of the groove. If these are not helpful, ensure that none of the splines on the shaft or inside the trans are damaged. You may end up replacing the retaining ring it is flattened or distorted. Try applying a bit of bearing grease on the ring to persuade it. Sometimes you will have to use a rubber mallet on the outer end of the axle shaft to get the ring to go into the trans.
Good luck.
Posted on Oct 16, 2009
cardenderek
  • 783 Answers
SOURCE: Janome 1600P The stitching on
Hello: To correct loose stitches, try the following: (1) Balance the thread tension. If the stitches are loose on top of the fabric, decrease the tension to the next lower number. If they are loose on the underside set the tension to the next higher number. (2) Make sure the needle/upper thread follows the threading path. (3) Check to see that the bobbin case is threaded properly. (4) Use a different size needle. For fine fabrics, use a smaller needle (size 9, 11); medium-weight fabrics require a size 14 or 16. And use a size 18 or "Denim" needle for heavy corduroy or denim. Fix Ya Support Please rate 4 thumbs up and leave feedback.
Posted on Aug 27, 2011
  • 662 Answers
SOURCE: janome problem
The hook is placed in. Now, there is a bracket that goes in front of it. This bracket is locked by turning little knobs on each side. Now you can push the bobbin holder in firmly with the little handle pointed up. If you don't push hard enough it will fall out.
Posted on Jul 02, 2014
Janome problem
Jun 30, 2014 | Sewing Machines
Pressure foot pressure control
The pressure foot knob had some problems. on this model. The solution was to remove the covers and the e clip that holds the knob in place. I install a belleville spring washer on the knobs shaft. This extra tension keeps the knob from turning when the sewing machine vibrates. This may be more difficult than most consumers want to attempt.
Oct 13, 2013 | Husqvarna Scandinavia 100 Sewing Machine
How to put the tension dial back on a janome
I am not familiar with that model but I suspect it is very similar to any other external tension knob. So go to singer under customer support and download a manual for a 127 or 128, or 66 or 15-91... read about and notice the photos. Understand how they work and apply that knowledge to your machine. ;)
Dec 12, 2012 | Janome Sewing Machines
Tension to loose and missing stitches
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
use a scrap piece of fabric to sew on as you adjust the tension
when the tension is to loose adjust one number higher till stitch
looks good
here's 2 links for a manual one is a hardcopy & the other is a
pdf downloadable--one is a different price from the other
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d.aspx
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d-download.aspx
Sep 08, 2012 | Janome MyLock 634D Mechanical Sewing...
I turned the stop motion knob in order to wind a bobbin and the knob fell off! I have tried to put in back together but now only the knob will move not the balance wheel. As as result the clutch will not...
There should be a washer that fits over the balance wheel, if you dont put that back on the machine wont work.
Check around and see if it fell off when you removed the knob, or check to see if it is stuck inside the knob.
The washer is about 1" in diameter with a couple little tabs on it.
It will only work when installed correctly so if at first you fail just turn the ****** over!
Aug 26, 2010 | Janome L-344 Mechanical Sewing Machine
I HAVE Kenmore 385 165 24 bobbin case is loose and I can not get even one stich. Do I miss a srew to hold it in a place? Thanks for help.
if the bobbin case is loose and pops out when started. it is not inserted correctly
make sure you hold the clasp when inserting case and hear the slick into place
make sure upper thread is threaded right and the bobbin thread is even
bring bobbin thread up and pull both threads to the back about fou inches
hold threads and stich a few stiches by hand or foot pedal befor letting fo of the thread.
Aug 26, 2009 | Kenmore Sewing Machines
My thread tension knob fell out of my machine and I can't get it to stay back in Model brother LS-1217
Open the end where the light is, look for a set screw at the point where the tension assemly enters machine. try tightening that. If that doesnt work, post a reply comment and I will tell you where to go next.
Mar 21, 2009 | Brother LS-1217 Mechanical Sewing Machine
Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Feb 08, 2009 | Janome Memory Craft 4800QD
Clutch Release Problem
You will need to remove the clutch release knob and the 3 eared positioner (the clutch) under that knob. Reposition the clutch on the shaft, put the knob back on and see if you can put the screw back in the hole. If it hits something, remove the knob, remove the clutch and turn it 180 degrees. This will reposition the ears. Put the clutch back on the shaft, put the knob back on the shaft and screw the screw into the hole. Test to be sure the knob releases the hand wheel to wind the bobbin.Be sure the thread is under the thread guide when you wind the bobbin and that there is a slight tension on it.
sewman7
Jan 16, 2009 | Brother Sewing Machines
Need a free manual for the janome 344
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link to them:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Jul 08, 2008 | Janome L-344 Mechanical Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
