Question about The Computers & Internet
My nextbook 5.1 NX16A11264 reboots every minute or two straight out of the box even what can I do
Don't matter if one app is open or none it'll freeze then reboot can't do anything on it bc of this
  • Dax Gustus
    Dax Gustus Aug 14, 2017
    Real helpful ROBCO WATER thanks.maybe am up date or some high speed low drag fix it app
    Champion:
    Scholar:
  • 239 Answers
If its 'straight out of the box', return it to vendor
Posted on Aug 12, 2017
Testimonial: "Thanks but na I'd rather tear it up more doing it this wày will u help or no .... Seen it back can't believe bc e u didn't even come back by with a real soluton but thanksi"
  • 147 Answers
SOURCE: Gateway Reboots Constantly
Okay Junior,
I've had a lot of customers have known issues with the 2Wire Modem/Router. The problem is its trying to be a router, while at the same time a modem. That's like trying to use one of those shampoo and conditioner all in ones - its not gonna work!
Your best bet is to ask them for a regular DSL modem, and then buy yourself a (preferably) NETGEAR router.
Please let me know if this helps. Take care and good luck!
Posted on Apr 02, 2008
SOURCE: System constantly re-booting
While this post is very late to answer this question, here is where I found a solution with the DVD still inside. When I used this solution, the whole system reset and worked.
http://www.tivocommunity.com/tivo-vb/archive/index.php/t-277275.html
"I had the exact same problem tonight. I put in a DVD and it locked my Toshiba RS-TX20 up. It simply wouldn't respond to anything but unplugging. Then it went into this infinite loop of trying to power up.
I finally got it to boot:
Hold the eject button on the unit continuously while it boots up (be patient!). It didn't open the tray until a couple minutes into the powering up process. After I took out the disc, it booted up normally at the next try.
I am guessing that there's a very small window during the booting process that the dvd drive isn't locked and you have to push the eject button in that small window to get the tray open. Since we don't know when the drive is unlocked, the best bet is to hold down the eject button continuously.
I hope this helps!"
Posted on May 16, 2008
  • 212 Answers
SOURCE: Why does my curor freeze up?
First I would replace the batteries. I had the same problem a couple of years ago. The solution for me was getting rid of McAfee AV. To check if it is your problem, use CTL-ALT DEL to turn McAfee off and see if that gets rid of your mouse freeze ups.
Posted on May 24, 2009
SOURCE: Freeze, reboot cycle
Just had this problem with my Tom Tom XL IQ Routes. Screen freezing and then rebooting exactly every 3 minutes just after I had done an upgrade to maps and application software. After trying a software reload and getting nowhere I solved it by simply doing a factory reset using the factory reset option in the units menu. No problem since. Couldn't believe it was that simple. I will however be keeping a very close eye on it!
Posted on Oct 12, 2009
ganeshkhatri
  • 173 Answers
SOURCE: Blackberry red light then reboots!
This behavior indicates that no applications are installed on the BlackBerry smartphone.
CAUSE: The Application Loader tool in BlackBerry® Desktop Manager removed existing
applications from the BlackBerry smartphone, but failed to install new applications.
RESOLUTION:-
1) Verify that BlackBerry Device Software is installed on the computer.
2) If the BlackBerry smartphone is connected to a laptop computer using a docking station,disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer.
3) If a third-party application uses the same communications port as the BlackBerry Desktop Software, close the third-party application.
4) If you use a USB adapter to connect the BlackBerry smartphone to a serial port, temporarily connect the BlackBerry smartphone to a USB port.
5) In the BlackBerry Desktop Manager, double-click Application Loader.
6) Follow the Application Loader tool prompts to install the BlackBerry Device Software.
Posted on Nov 19, 2009
Why does my nextbook keep asking me if I want to put it in safe mode?
The device went into safe mode because the app that you downloaded was not a safe application. The device does this so that the application cannot cause more problems to your device. Even though the app was downloaded from the app store it was not deemed safe by your device. Here are some tips that will help you to get your device out of safe mode: -Ensure that if you have a case on your device that you take it off being that the case may be holding the volume button causing you to boot into safe mode -Try turning the device off then back on to get out of safe mode -Power off your device, then reboot by holding the power button + volume up key, then in the boot menu select reboot device -This is sometimes caused by the users accidentally tapping safe mode when cutting the device on so simply restart your device Most users have success by simply restarting the device in order to be able to get out of safe mode. Do your best to restart or reboot your device before you have to perform a hard reset to get the app off of your device to no longer go into safe mode In order to hard reset -Power off device -Hold down volume up + power -Release at the boot menu -Use the volume keys to highlight factory reset -Press the power button to select factory reset -After this the device will begin to reset itself -After it resets itself use the volume keys to highlight reboot device -press the power button to have your device rebooted in its factory settings
Apr 20, 2016 | Nextbook Tablets & eReaders
How do I get my nextbook tablet out of safe mode?
Nov 04, 2015 | Nextbook Tablets & eReaders
How to unlock apps on nextbook
1. Back up everything you feel is important before you start.
2. Charge your device to 75% or more before you begin to prevent unwanted shutdowns.
3. This method will only work for the versions of Nextbook 8 bought before August 2013. Check the back of the tablet and if the serial number begins with YFG1013, YFG1113 or higher, this procedure is not for you!
II. Necessary Downloads
1. SMT_Next8HD8G_Mod_Recovery.zip [Download link available in this post]
2. Kyser_Root-signed.zip [Download link available in this post]
III. Rooting the Nextbook 8
1. Extract SMT_Next8HD8G_Mod_Recovery.zip to a folder on your desktop. You should end up with a file calleduImage_recovery with no extension.
2. Connect your device to your PC and copy both uImage_recovery and Kyser_Root-signed.zip to your device's external SD card (not the internal memory, insert a microSD card if you don't already have one); do not put them into any subfolders just drop them in the main folder of your device's external SD card.
3. Power down your device and reboot to the modified recovery you have just copied. To do this, with the device powered off, press and hold the Volume Up + Volume Down buttons with the Power button until you pass the splash screen, a black screen and you see the recovery menu.
4. Use the Volume Up and Down buttons to highlight the 'Flash zip from EXT card' option and the power button to confirm the selection.
5. Once flashed, go back to the main menu and select 'reboot system.'
Once the Nextbook 8 reboots, check for the SuperSU app in the app drawer (install it from the Play Store if you don't find it) to verify you are rooted!
Sep 29, 2014 | Tablets & eReaders
Ebook not working on nextbook 8
it happened to me all I did was just charged it
Jan 17, 2014 | Nextbook Premium 8 Se Android
How do i keep my nextbook 8 from resetting itself to the factory setting everytime i shut it off
Happened to me today. Fix: Boot it up and go to Settings > Backup & reset > Factory Reset: Check the Erase SDCard Data Box. Make sure you backup all your important information to the External SDCard first using Astro or something. Enjoy your fixed tablet after rebooting again and going through the Wizard for the Last time.
Dec 28, 2013 | Nextbook Premium 8 Se Android
Clear cache
To clear up memory. These items clutter your drive.
May 12, 2013 | Nextbook Premium 8 Se Android
My battery goes dead over knight i have had it replaced now the car will not start it just keeps turning over someone said something about the B C M
Body control module, does it have a manufacture alarm try this see if it reboots take both terminal out and put it together for 5 minutes, put the terminal back together, and in the normal matter start it see if that reboots the BCM make sure the battery is good before you do it
May 09, 2011 | Chrysler 300M Cars & Trucks
Computers & Internet Logo
70 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
