Question about Refrigerators
I have a waco gf50 with led temp display, setting it on 2 leds the fridge runs too hot , set on 3 leds the fridge starts to freeze food, is there an internal adjustment to find a happy medium, thanks
  • 93 Answers
SOURCE: GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Posted on Jul 17, 2008
SOURCE: whirlpool frost free tropical, seems
Check the sensor in the refridgerator... on the right,,
Posted on Sep 22, 2008
awcforever
  • 359 Answers
SOURCE: Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Posted on Jan 30, 2009
  • 145 Answers
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
Posted on Jun 07, 2009
SOURCE: Hello i have an lg refrigerator GR-620RW which
LG 620 RW water in fridge below crisper problem.
The issue is most likely a blocked condensate drain line at the back of the freezer. The purpose of the drain line is to take away the water from the end of the defrost cycle.
Task time, approx 2 hours.
Unplug fridge.
Empty out the fridge, let warm up & remove the back panel of the freezer. There is a 3" x 4" snap in door at the upper left corner of the back panel with a round snap in cover. Remove the snap in cover & remove the screw to take out the 3" X 4" panel, gently pull out the back panel from left to right. There is also an elect connector to the fan on the upper right corner, unclip this. The drain is at the back in the centre, it will likley be blocked with 2 or 3" of ice. You can let it melt or sparingly use a hair dryer on it, do not over heat or damage the coil/fin assembly. The fridge will continue to drip water for a day after the drain is cleared if the water has rin inside of it for any period of time.
There is also a fan/control assembly in the refrigerator section held up by 2 screws & snaps. This should be dropped down to ensure there is not ice buildup in the vents to the freezer or water inside it.
Finally, make sure you run warm water down the freezer drain tube to the pan underneath the fridge, this is accessible by taking of the rear compresser cover behine the frigde. Ensure the lower drain line is clear & back on the locater peg.
Of course if you want to do this the easy, & have the time, leave the fridge open, unplugged for 2-3 days & the ice will all melt.
Good Luck
Posted on Jun 19, 2010
How to set temperature on GE Profile PSS26NGPA WW?
Press and hold temp up button then press quick freeze button at the same time, your temp settings will be displayed on display for fridge and freezer, fridge temp is + and freezer -, cycle by pressing quick freeze, set temps by up and down temp buttons, once done, push vacation button. your temps are now set, turn the unit off for 2 mins the turn on. reaction is now set and normal. regards Russ
Jul 03, 2012 | GE Refrigerators
I have a hot point side by side refrig and the dispenser is frozen. How can I fix this problem
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
I hope this will solve the problem....
May 07, 2011 | Hotpoint Refrigerators
My gsh25jsxjss fridge is too cold. the electronic settings do not change the temp in the fridge.... even if I put it on the warmest setting... food is freezing in the fridge area
HELLO,
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, please do check that to confirm the deflector is okay or not....
Hope this will help in solving the problem......
Jan 12, 2011 | General Electric GSH25JSXSS Stainless...
My fridge keeps beeping even though the door is shut. The fridge temperature indicator keeps going up and then down. Can you please tell me what's wrong?
If the reset procedures don't stop the beeping and you are out of warranty, here is an easy fix:
1- (You can unplug the fridge just to be cautious, but not necessary.) Remove the control panel from the front of the fridge. Mine pulls straight out without removing any screws.
2- On the back of the control panel is a black, round device - the only thing that pokes through the back of the panel. This device is small, maybe 1/2" in diameter and the same deep. (if it won't pop off easily, remove the 4 screws to remove the back cover for easier access.)
3- You will see a thin round disk inside. This is the speaker. Remove this disk, press the black speaker cover back on and press the control panel back into the front of the fridge.
All the controls will continue to work as before, but NO BEEPS!
Yea!
Nov 08, 2010 | Samsung RS2630SH Side by Side Refrigerator
Food freezes in the refrigator
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
May 20, 2010 | Whirlpool GD5SHAX Side by Side...
Food freezing in fridge compartment in my side by side
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Jan 26, 2010 | KitchenAid KSCS25FKSS Side by Side...
Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Jan 13, 2009 | Refrigerators
Haier Wine Fridge problem
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 30, 2008 | Haier BC112G Wine Cooler
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
