Mg Sandi Lifepad don't want to charge Light go on but dont charge
Mg zr common faults
Bad cabling.
You need to check earth for the motor.
If you are getting bad earth then it will overload the fuse.
Jul 11, 2014 | 2005 MG ZR
Mg metro alternator
Only needs two wires, run a 40 amp cable from the large terminal on the alternator marked +, direct to the positive terminal on the battery or to the battery supply feed to the starter (which ever is easier). Then run a wire from the terminal marked 'ind' to a 5watt bulb, other side of the bulb needs to be wired to an ignition live feed. That's makes it the charge indication light. You need to fit this light, without it the alternator will not charge!!!! Light will come on when you switch the ignition on, and go out when the engine is started. Put a volt meter across the battery, should get a reading of 13.5 to 14.5 volts with engine running. Good Luck.
Dec 31, 2013 | Cars & Trucks
Cindy coalaa tlg bantu saya lupa sandi keamanan di poker id tks
tolong kasih tau saya tanggal ulang tahun pacar saya
Sep 23, 2013 | Facebook Apps
Saya lupa kata sandi poker id saya
ID SAYA 2778193 detteckcomunity@yahoo.com
no hp 085241987081
MASALAH = LUPA KATA SANDI
Aug 18, 2013 | Facebook Apps
Sansui lifepad etab 704vp pc software download site?
software for pc to dawnload on sansui lifepad etab 704 vp
Jun 16, 2013 | Televison & Video
Mg tf battery not charging
is the charge light coming with the ignition and going when the engine starts?if it is on all the time check the alternator and drive belt the belt may have broken
Dec 12, 2012 | 2004 MG TF 120
Minta kode atur ulang kata sandi di facebook
kata sandi saya selalu ada yang ganti , dengan orang2 yang tidak mau bertanggung jawab . tolong donk untuk informasi nya bagaimana agar password facebook saya tidak diganti lagi
Dec 03, 2011 | Facebook Social Network
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
