How can I change the audio with the audio button on my DVD of ''Night at the Museum''?
Every time I press the audio button on my DVD of ''Night at the Museum'' I keep getting a no signal. How can this be solved?
When I try to play namco museum megamix my contollers stop working
you need to press a button. if it doesn't work still, then it may be a bad disk.
your guy for help,
ElijahCruz
Even kids can help :)
Jul 23, 2012 | Namco Museum Megamix for Nintendo Wii
How do I select the recording speed "SP" mode on my Panasonic DMR-E55 DVD recorder
1 Press [< OPEN/CLOSE] on the main
unit to open the tray and insert a disc.
≥Press the button again to close the tray.
2 Press [W X CH] to select the channel.
To select with the numbered buttons:
3 Press [REC MODE] to select the
recording mode (XP, SP, LP or EP).
4 Press [¥ REC] to start recording.
Recording will take place on open space on disc. Data will not
be overwritten.
≥You cannot change the channel or recording mode during
recording.
≥[RAM] You can change the audio being received by pressing
[AUDIO] during recording. (Does not affect the recording of
audio.)
Feb 02, 2010 | Panasonic DMR-E55 DVD Recorder
Instructions to 'science museum' radio controlled alarm clock
press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
Jan 05, 2010 | La Crosse Radio Controlled Atomic Clock
I had sound yesterday. left on all night - no sound today
Sounds like you did hit a button on your remote. More than likely it's an audio button on the remote. This button typically selects an audio track on the dvd itself. It's either this or somehow during setup you've selected (depending on the rest of your audio setup) either the bitstream or PCM output for sound. I would just try hitting the audio button until you get something, or go into your dvd setup and try changing from either bitstream or PCM to the other choice.
Jan 16, 2009 | Yamakawa DVD-238 DVD Player
How to set up remote to turn tv on and off
this is a generic answer that applies to many multi unit remotes
Many remotes have to be trained. the user manual contains a list of code series that identify to the remote what equipment the remote is intended to control. changing batteries may erase the prom that this information is recorded in.
From either the printed manual or by looking up the manufacturers web site from descriptive labels on or in the remote, you can determine the (usually) 3 digit code for your tv dvd video audio units and the button that begins programming mode sop that you can press the unit button, enter the code, press the button to confirm. and be done
My specific remote requires
Hold [menu] untill the red lamp flashes 3 times
press [dvd]
enter the code on the number pad
press [dvd]
press [tv]
press [tv]
press [vcr]
press [vcr]
press [audio]
press [audio]
press [aux]
press [aux]
press [menu]
thankfully the remote recharges on the dvd player, and I only did that once
May 03, 2008 | Televison & Video
Remote does not work after changing batteries
press [dvd]
press [dvd]
press [tv]
press [tv]
press [vcr]
press [vcr]
press [audio]
press [audio]
press [aux]
press [aux]
press [menu]
May 02, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Audio Problem
1 In ‘AUDIO SETUP’, press OK to enter
the submenu.
2 Press 3 4 to highlight {Night Mode}, then
press OK.
3 Press 34 to highlight one of the options
below:
ON
Select this to level out the volume. This
feature is only available for movies with
Dolby Digital mode.
OFF
Select this when you want to enjoy the
surround sound with its full dynamic
range.
4 Select an item and press OK.
Mar 14, 2008 | Philips DVD 622 DVD Player
Problem with taking pictures
go under scenes on your camera
&& there should be a list saying in exact oreder
-auto
-P-mode
-portrait
-night portrait
-landscape
-sport
-night landscape
-backlight
-museum
-snow
-sunset
-fireworks
-party
-beach
-copy
-video
you have selected video
so whe you press the pic button it starts to record right?
well go under scene && click on auto
any other question ?
-alikins :)
Dec 22, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
JVC XV-511 Audio OK with CD but none with DVD
Walks' solution worked for me! Thanks lots! I was about to head to the repair store!
Nov 29, 2007 | JVC XV-511 DVD Player
Plasma tv with suspected SAP turned on
Hi
Try going to the audio menu then audio language and see what your settings are also try going to the options menu then caption/text and see what your settings are also in the options menu go to caption option. if that doesn't help try the same thing with the dvd player. hope this helps.
May 28, 2007 | LG 42PC5D Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
