Question about The Watches
The battery inmy watch wont come out, the little covering is trapping it....
    Champion:
    Scholar:
  • 239 Answers
There is usually 1 to 3 screws holding down the battery cover. if you do not have the tools or expertise to remove it, go to a jeweller and get it done. it will usually cost less than $20
Posted on Aug 12, 2017
How do I change the WATCH battery?
With very small and flat bladed screw driver you pry the back cover off and the battery will be right there. Remove and replace.
Some watches have little screws to hold the plate in place and you work on those instead to do the deed.
Sep 04, 2015 | Casio Mens Classic Watch Aw437e1v
My Abacus Fossil AU4005 110504 wont charge any more,wen i put it on the charger nothing happen,it does not light up any more,do i need a new battery and where do i get it?
I had the same problem but easy fix.
first make sure you put the watch on charger for a few hours first-- the problem is not the battery not taking charge it is the watch that is not turning on probably.
After a few hours on the charger, remove the four screws on the back cover-- WARNING- remove cover carefully. there are two thin copper wires attached to the cover to the charing coil. set the cover aside. remove battery back (unplug tiny connector). WAIT a10 minutes-- this is to discharge any remaining charge that may be held by capacitor in the watch. plug the battery back in. Voila! working now. This is my way of resetting the watch to factory setting. Isn't it almost always work when you remove power to electronic device to reset it?
Nov 09, 2012 | Fossil Abacus AU4002 wristwatch
How do you change battery for casio 1174 CMD-40?
I like these little RC IR watches. They're great fun!!! For this tutorial, you will need....
  • A small Phillips heads screw driver
  • A pin (or needle)
  • A replacement CR2032 battery
Instructions :
  1. Remove the 4 screws from the back of the watch
  2. Carefully remove the back plate, do not damage the delicate rubber seal
  3. Carefully remove the delicate rubber seal
  4. Use the pin to remove the small rubber block from the battery cover clasp.
  5. The pin should then be inserted in the gap of the white plastic lug, where the rubber block was removed.
  6. Use the pin to gently pull back the clasp of the battery cover.
  7. The battery cover will then open with a 5mm gap approx. It does not need to be removed.
  8. Use the screwdriver to remove the battery.
  9. After the battery has been replaced, just follow the instructions backwards.
I hope this little tutorial has helped.
Feb 10, 2011 | Casio Watches
I have a womens Columbia watch that is also water resistance to 65 meters. The battery has gone dead and I would like to replace it. Most watches have a groove to pry the cap off. This watch does not have...
mcdevito75 here, Hello Traudl, I see what you mean by not seeing or haveing that little tab on the back cover to pry off the back. I'm not an expert but do know a little about watches. Look again for this tab on the back cover, use a magnifier glass available at all Dollar stores to see this tab. Of course you may be right and there isn"t a tab, in that case look carefully between the back cover and the case of the watch for a cutout, it should be somewhere between the back cover and cvase of the watch, it"s very easy to miss this is why I suggest the magnifier glass. If by chance the back cover has square holes going around it"s circumference, then you would need a special tool to unscrew this back cover, I don"t think so though. If all this fails then your best bet is to look for a small watch repair shop in your area for a new battery. Hope I've helped.
Sep 13, 2010 | Columbia Watches
I took the back off a watch to change the battery now i cant get the back on
mcdevito75 here Look very closely at the back cover for anything that will line up with the case, as an example a little cut out in the cover for the stem (winder) and or any small indent in the cover and case or tab on the cover, line everything up carefully then place the watch face up on a sturdy table, countertop and with the palm of your hand press down evenly, this should snap the cover back on. If Not, see a small watch repair shop in your area as they will use a special pliers to clos the back cover.
Jul 05, 2010 | Watches
I am writing to file a complaint regarding my wife's watch. The watch was purchased Dec. 2008. It stopped working twelve months later. The limited warranty stated that the watch would be repaired for...
Warranties only cover a failure due to manufacture. Unfortunately dead batteries are not covered by any maker as there is nothing wrong with a watch if the battery fails.
I year does seem a little short. Perhaps it was running for a time before you bought it? Who knows!
Feb 16, 2010 | Watches
NEW BATTERY. NO CHIME OR BEEPS ON THE HOUR,TIMMER, AND ALARM WHAT CAN I DO TO FIX THIS PROBLEM
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry2.gif & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
email: info@goamfix.com
web: www.goamfix.com
Sep 14, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Cant keep time
there is adjustment for that inside of watch or it just may need a little cleaning inside recommend take to jeweler and have serviced if you want to try cleaning at home simply take off back cover and clean with a little cigarette lighter fluid put little bit in wash around and drainout (do not soak) allow excess to evaporate out and replace battery and cover hope this helps
Sep 05, 2008 | Timex 27191 Wristwatch
How do I release the battery clip on a Timex Expedition watch to change the battery.
I just had this problem, and my 8 year old and I had to fiddle a bit to figure it out.
Just to confirm, you have removed the back cover and taken the watch guts out of the face and strap assembly and are looking at the battery which has a cover over it and maybe a sticker on the cover that says "unlatch to remove battery", with two >'s, one pointing to to each side?
On each side there are two small metal tabs, which surround a small moulded-in plastic piece with an opening in the middle.
The release is in that opening in the plastic piece. You need to fish around in that opening a little to catch the release and push it outward toward the edge of the watch (away from the battery). You need something very small to do this with, like a straight pin. If successful, the cover pops up on one side and then you do the same on the other side.
Good luck.
Jul 20, 2008 | Timex Watches
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Mar 15, 2007 | Fossil University of Oklahoma LI2282 Sport...
Watches Logo
19 people viewed this question
Top The Watches Experts
John mullen
D. E. Hev
 En Sukkert
En Sukkert
Level 1 Expert
Are you a The Watch Expert? Answer questions, earn points and help others
