ELEPHAS 1500 unable to get a bright image - is there a way to increase brightness?
Pyrhyc
  • 2028 Answers
SOURCE: xps screen brightness low
Press F2 at start up to go into the bios. There is another setting in the bios for the screen brightness while on battery power.
Posted on Jul 15, 2008
kevin000
  • 1847 Answers
SOURCE: After being dropped Fn keys no longer control Screen Brightness
Try change the brightness from the BIOS and let me know the status
Thanks
Kevin
Posted on May 27, 2009
  • 280 Answers
SOURCE: can i adjust the brightness of the screen?
Laptops are provided with a combination key that can increase and decrease brightness. Find on your keyboard 2 keys with a bulb and an arrow key. Mostly you'll have something like a sun. Hold down your FN key (near your left ctrl key) and press one of those keys depending on whether you want to increase or decrease brightness. In Dell the keys will the arrows keys themselves
Posted on Jun 26, 2009
  • 191 Answers
SOURCE: Laptop brightness
The physical control is found by holding the 'fn' key in lower left and pressing a function key. Which function key...look across the top row of 'f#' keys for one that has a little sun shape and an up arrow. Press the 'fn' key and this function key to up the brightness.
Software control can be found by going into the Control Panel and selecting Power Management. Here you can define how bright (or dim) your computer is in different states (plugged into power or on battery). You can also define how the computer behaves when left inactive for certain amount of time and how the power button works when pressed while computer is on.
For more info, use your Windows help feature or your Medion user's guide. They should be able to tell you how to control brightness.
Posted on Oct 04, 2009
SOURCE: Increase brightness
I just figured out that you had to press the Fn key and the RIGHT ARROW key to increase the brightness and the LEFT ARROW key to decrease it ( and not the Up and Down arrow keys)
Posted on Mar 04, 2010
Previously i have minimized brightness and now i am unable to increase it ?
If controls won't work, guess your device is defective. According to it's value, verify if it's wotrh to repair ir.
Aug 13, 2014 | Creative Labs ZEN V Plus MP3 Player
When plug is remove from laptop the screem get darker
This is natural. In the power settings, usually it is set to reduce the brightness when laptop is on battery power.
you can increase the brightness, but it will drain the battery quickly.
To increase or decrease brightness, use one of the buttons indicated on the keyboard with 'Fn' button on the bottom of the keyboard.
Thanks for using FixYa!
Sep 16, 2011 | Dell Vostro 1500 Notebook
How to increase the brightness of my hp compaq lap top
There should be brightness controls on the keyboard. Look for a key with the image of a 'sun' or 'light' symbol.
Mar 10, 2011 | Computers & Internet
The projector is not giving a bright picture. The image on the wall is very dim
I you were using the projector in the same room with the same ambient light and if you notice this problem try increasing brightness, if still the brightness is not sufficient then it is time to replace the projector lamp.
If you have moved your projector to a different place, check if the existing light / ambient light in that room is making the image look dull / not so bright. If this is the case, try to reduce the ambient light
Mar 09, 2011 | Dell 1100MP Multimedia Projector
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Adjust screen brightness evo N600c
using the blue Fn key(usually on bottom left to side of space bar)..look at Funtion keys on top, under the screen. One of them(F5 or F8) will have a blue sun image or a monitor image to increase or decrease the brightness. press the Fn key first, then the one that increases brightness until it's good .
Nov 28, 2009 | HP Compaq Evo n600c Notebook
Can i adjust the brightness of the screen?
Jun 26, 2009 | Dell Latitude D630 Notebook
How to increase brightness of the photograph ?
Use a free image editing software like Picasa from Google. http://picasa.google.com/ . You can perform basic photo editing tasks easily using this including brightness, colour, crop, resize, redeye etc. For Professional editing you will definately need Adobe Photoshop.
Mar 02, 2009 | Adobe Computers & Internet
My Dell Inspiron 6400 is extremely dark. +brightness does nothing
Hi there.
Yes, if you can see a very faint image on the screen that indicates that the inverter or inverter coil has become defective and needs looking at or replacing.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Dell Inspiron 6400 Notebook
To increase the brigthness and contrast
i have a gateway laptop and i would like to increase the brightness
Jan 12, 2009 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
David Payne
David Payne
