Question about Siemens Washing Machines
I have a Siemens siwamat 6102 washing machine which keeps stopping during a cycle showing error code 3 - does anyone know what this means & how I can fix it?
SOURCE: SIWAMAT 6102 (GB) Code 3
The pump was working but not pumping. The rubber hose from the bottom of the drum to the pump was removed and found to be partially blocked. The debris inside the rubber hose was cleaned out and reassembled with no further problems.
Posted on Sep 08, 2008
localwonder
  • 6784 Answers
SOURCE: Keeps stopping during wash cycle with LF code
This code is representing a long fill situation, have the pressure switch replaced asap. it has failed.
Posted on Aug 13, 2009
SOURCE: Siemens Siwamat 2105 washing machine leaking
Ater beeing switched on the machine does not fill with water.
Posted on Jun 22, 2010
SOURCE: hi there does the siemens
Yes - mine has just frozen in the garage and cracked whilst defrosting. Water everywhere. Does anyone know if I can bypass it and run the M/C on cold only?
Posted on Dec 29, 2010
richroth
  • 9472 Answers
SOURCE: My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Posted on Oct 16, 2012
My siemens siwamat xlp 1340 shows a lock key and wont operate
that means that the door catch is not operating properly you may need to replace the door lock yourself or call the washing machine engineer for a quote eric
Jan 13, 2018 | Siemens Washing Machines
My washing machine is leaking a lot of water during a cycle - underneath in the front. Could there possibly by a back log of water? I have drained it, but it's a lot of water.
You will need to open up the front or rear panel and inspect the hoses before and during operation to see where the leak is. There are many Youtube videos on how to remove the panels. Good luck!
May 18, 2016 | Siemens Washing Machines
Kenmore washer
I need manual in English for SIEMENS SIWAMAT 6102 can anyone send me one? Tx
Jul 07, 2013 | Washing Machines
Take the top off.
Oct 15, 2012 | Siemens Washing Machines
Hi there does the siemens siwamat 6102 washing machine have an hot water inlet valve, Regards Robert
Nov 25, 2010 | Washing Machines
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
SIWAMAT 6102 (GB) Code 3 Flashing. What does this error mean
Sep 07, 2008 | Siemens Washing Machines
Error codes
If this machine is like other of its type then you may find the manual taped to the inside of the machine near the bottom side panel.
open the bottom access panel (3 screws on bottom front lip) and look for it as it will have the codes. near where the filter is .
while you were down there cleaning the filter did you check that the pump impellers move freely and were not clogged with any debris.
Jan 28, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
