Question about Sewing Machines
I have a Sharp Carousel Microwave , Model R-8350. Serial 01091. Recently I set the cooking time on a small pizza for 10 minutes when it should have been 1.5 minutes. The pizza burned in the oven I have cleaned the entire oven, and in doing so found am oblong piece of cardboard like paper with a shine, perhaps 3" x 6" at the top right hand side of the nside oven top. The material on the cardboard had bubbled. I removed this cover and wonder how to get a new one. I have no idea if it is a waveguide cover, but in my manual there appears to be an arrow in a diagram pointing to it as such. The Microwave appears to work well, but I am uncomfortable with replacing this cover with the damage done to it. Considerable smoke damage occurred in the kitchen but the Microwave seems to be unharmed except for this piece of cardboard like paper which covers something in the inside top of the unit.
    President:
  • 563 Answers
I hope I've provided you useful assistance and that this informationallows you to make an informed decision as to how to proceed fromhere. Please be sure to vote on my response. I hope I've earned agood rating from you today.
Please post a comment if you needadditional assistance so that I can help you further.
Posted on Jul 27, 2009
Will my PED BASIC work with windows 10
There is a version of the Brother PED-Basic that will work with Windows 10. Go to http://support.brother.com/g/b/downloadtop.aspx?c=us&lang=en&prod=hf_basiceus , and accept the EULA. This is a free update.
However, check if your sewing machine will work with Windows 10. The list is here: http://support.brother.com/g/s/hf/os/windows10/win10_hsm_us.html . With some sewing machines, no USB driver is available for Windows 10. For these, you need to put the designs on a USB flash drive to import them on the sewing machine. For other machines, you may need to add a serial port card to the computer or get a USB to serial port converter to connect the card reader/writer. See https://www.amazon.com/Trendnet-TU-S9-USB-Serial-Converter/dp/B0007T27H8 for one model. (Note: you may need a different converter. The best converters have an option to change the pin assignments. A lot of older serial devices did not use the pin standard that was eventually developed.)
I hope this helps.
Oct 29, 2017 | Sewing Machines
I have a Janome DB-628 serial no 8061246 where can I find a instruction manual thanks mr George cook
Search the internet for:
Make + Model + the word "Manual"
or contact manufacturer support.
Apr 18, 2016 | Janome Sewing Machines
Tension setting for small straight stitch on a Kenmore 10 Stich model 385 1249380 sewing machine.
Please go to Kenmore model 385 1249380 sewing machine sell shop and ask the machanic or shopkeeper.
Jan 01, 2014 | Sewing Machines
Thumping noise
change the needle again, when you hear a thumping noise that
means the needle is either damaged or not the right one for the
fabric
adjust the top tension one letter or number higher till the stitch look
better
it show the machine name is bernina model is 440,, so I'm putting
in a link for a manual for the machine
http://www.bernina.com/getdoc/56b4ec85-1b1b-4d17-8519-e892adfa5fa2/032907-52-04_1103_a430_a440_a450_EN
if this is not the manual, then let me know & I will find you another
one.
Sep 05, 2012 | Bernina Sewing Machines
Where is the serial/model number on a 1959 Singer sewing machine?
The model number should be on the front right hand side of the machine (motor side) just above the base. For a picture of where the plaque is located, see http://www.singerco.com/support/machine-model-numbers . I'm not positive where the serial number would be for a 1959 machine.
(my Singer machine is newer by 10 years.)
Nov 29, 2011 | Singer Sewing Machines
Model 385-15343600 Serial 71073690 The stitches are very, very small all the time regardless which of the tension used (bobbin and needle).
The stitch length dial needs to be set to a lower number (number of stitches per inch) to give you longer stitches. The tensions do not regulate the stitch length, the feed dogs regulate the distance the material is advanced between stitches. Also, make sure the pressure foot is applying enough pressure to keep the material in firm enough contact with the feed dogs.
<Ray>
Nov 11, 2010 | Sewing Machines
Pfaff 360 automatic slows and stops after only minutes of use
Pfaff 360's don't like to sit, they like to drink. . .. oil.
Set top knob "C" to 0
Right top (zig-zag knob) set to 4, lever below but on the same dial points straight down. Set stitch length to 4. Run 5 minutes medium speed.
After that lift off the top cover and spray inside with "Tri-flow", then run a hairdryer on it for 20 minutes to warm up or set near a warm lamp overnight. Run daily 5-10 minutes and exercise the right knob between 0 and 4 (zig-zag). It should come back to working with oil, time, and heat.
Apr 13, 2009 | PfaFF Creative 7570
Sewing Machines Logo
93 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
