Question about Salter Health & Beauty
How do I salter scale 6300 changed to grams not oz
Salter high precision stainless scale 1078ss. How do i get it to weigh ounces
Put the weight on the scale. It should weigh ounces, pounds, grams, and killograms, all in the same unit.
May 12, 2017 | Salter Health & Beauty
How do I switch from grams to ounces on the Polder kitchen scale?
There is a button on the back of the scale with "g/oz" below it. This changes your scale from grams to ounces or vice versa.
Feb 24, 2015 | Polder Slimmer Digital Scale
Am trying to add clarification to an earlier question. The scale I am asking about is a wall mount kitchen scale: the make is Salter, the model 1601. It worked fine for several years until I changed t
Is it possible you put the batteries in the wrong way? Sometimes a device will still have power in that situation, even though it won't work as expected. Try a new set of batteries, but clean the contacts in the battery compartment first, and double-check the battery orientation.
Dec 20, 2014 | Salter 2001 electronic kitchen scale
Change lb to gram
Number of grams multiplied by .0022 = lbs,
Dec 10, 2014 | Salter 2001 electronic kitchen scale
I have the Salter Scales model 2040, it is currently sent to oz, do you know how to change to grams as there is only 1 button. thanks
I just had a play with mine as I wanted to change the weight mode too.
The solution is this:
While the machine is OFF, press and hold the button for about 5-10 seconds.
The display will go from 8888 to show the weight measurement (lb oz) at the top of the display.
Press the button to select the weight you want.
You should be able to continue with your baking :o)
Hope this helps
Oct 09, 2010 | Salter 2001 electronic kitchen scale
I have a set of hanson kitchen scales and i cannot change it from fl oz to grams etc
To switch your Hanson kitchen scales from ounces to grams, press the on/off button until you see the display change to the measuring scale that you require. This change option is ONLY available as you are switching on the scales, so if it already on - switch it off first and start again from scratch. Once you have set it to grams, it will remember your choice for next time, so you don't need to worry that you have to do this every time you switch on.
I hope this helps. Good luck.
Feb 08, 2010 | Health & Beauty
Setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Oct 06, 2009 | Salter Bakers Dream Aquatronic Kitchen...
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
My salter 1004SSDR kitchen scale won't show any real weight - just stuck on '5000' which is the max weight in grams, won't switch off, crazy
Your salter scale has a 15 year warranty. I would call the customer service number 1-866-843-3905 and ask them why it won't zero to weigh anything. They may replace your product.
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
Health & Beauty Logo
65 people viewed this question
Top Salter Health & Beauty Experts
vince
Andrew Taylor
Andrew Taylor
richie46
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
