Question about Cell Phones
I have an iBigBoy and can't attach my iPhone 5 or 6, only earlier models of iPhone. Is there an attachment I'm missing for this? The port on the bigboy is the wrong fitting.
Benimur
  • 6966 Answers
SOURCE: Havimg prob with the 2 usb ports located in front
Hi manky, Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
Posted on Jun 01, 2007
SOURCE: saving attachments from iphone email
on 3G...touch the options arrow button at the bottom and you have choices for the email, to include saving the image. Once you do so, it will be saved on your iphone's camera roll.
Posted on Jul 22, 2008
SOURCE: Can't send an email attachment from iphone.
make sure that you downloaded the (named)rssfeed.under the category in the INStaLLer alrigth.
Posted on Jan 07, 2009
  • 16 Answers
SOURCE: Hampton Bay Ceiling Fan
Are you talking about a Hampton Bay ceiling fan product. Is there a label stick attached to the top main housing unit that indicates the model & UPC #. If it;s a Hampton Bay...
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Posted on Jan 21, 2009
  • 3 Answers
SOURCE: Can you tell me if
i think your confusing model #s ,as the 116. 22512202 is the canister model number and the model number of the powerbrush attch would be 116.52512202,but to answer your ? no it depends on which wand your useing that determans which one you can use
there 3 types of wands 1 telescoping which comes only on progressive models 2 a 2 piece with wire connected and a 2 piece
wire not connected,hope this helps,les
Posted on Mar 05, 2009
I took apart my iphone 5 and now it keeps going to recovery mode
take it to the apple store and tell em you want a replacement, you get 1 year warranty on iphone 5 i beleive
Jul 04, 2013 | Apple iPhone 5
Skimmer hose collapsing
There is variable suction valve that attaches to the vacuum port that I believe is missing that keeps this from happening, attach it an it wont happen again.
Jun 01, 2013 | Hayward Pool & Spa
No phone dectected
reset the device. turn it off, press and hold the volume plus and the green button until you hear a siren. turn off the st3 and turn it back on. choose the language desired then search for devices using your phone
Jan 12, 2013 | Blueant Supertooth 3 Bluetooth Handsfree...
I need help fixing my home network. One of my family members decided to try and daisy chain two routers together and now I can't get them to work again through the 5 port switch. Each router will work...
You should hook one router to the modem through it's WAN port
Then attach the switch to the router
You can then attach the 2nd router to the switch if you want to use it as another switch
It will not work attaching the switch to the modem first
Jan 31, 2011 | Belkin F5D5131-5, 5-PORT 10/100 NETWORK...
How to put freon in?
Warning: It's a federal crime for anyone not EPA certified to charge a unit.
With that being said,The charging ports are located on the outside unit,You will need the proper set of gauges,an outside ambient air thermometer,a jug of refrigerant,an adjustable wrench,and the proper size allen wrench.
You will need to attach one end of the yellow(center) hose to the tank(leave the valve on the tank closed for now) and leave the other on the gauge manifold,Attach one end of the blue hose (left)to the suction line(the big one) and leave the other attach to the gauge manifold,Attach one end of the red hose(right) to the high pressure line(The small one)and leave the other attach to the gauge manifold.You will then need to take the temperature around the unit(ambient temperature)once this is done,you are ready to charge the unit.
You will need to remove the brass cap on the charging port,Insert allen wrench and slowly open the valve,the pressure on the gauges will rise to the current pressure,You will now need to start the unit and let it run for about 5 minutes or so,until the pressure stabilizes on the gauges.With the temperature from earlier you can begin charging the unit,but without me knowing what the temp is I can't tell you what pressure to charge it to,So the remaining steps cannot be completed.
May 16, 2009 | Weather King 10AJA6001AH Air Conditioner
Jan 06, 2009 | Apple iPhone Smartphone
Palm to iPhone
Assuming you are using Palm desktop, have an email account, and can receive emails on your iPhone:
1) Open Palm Desktop on your computer and click on Contacts.
2) Click on Categories and select "ALL".
3) Go to Edit and click "Select All" (all contacts should be highlighted)
4) Go to File and click "Export Vcard"
5) A dialog box will prompt you for a file name. Use what every name you prefer, but remember the file name and location. Your contacts will all be saved as a vCard file (vcf)
6) Now go to your email account and send yourself an email and "attach" the file you created from step 5.
7) On your iphone, receive the email from step 6 above. Scroll down to the bottom of the email and you will see the attached file from step 6 above.
8) Click on the attachment and you will be prompted by iPhone to add the contacts to your contact list. Follow the intructions.
Should work like a charm! [There are other ways of exporting from Palm to the iphone by exporting from Palm to a CSV file and then importing, after mapping fields, to either a Windows Address Book file or an Outlook (not Outlook Express) file. The advantage is the ability to sync on a batch basis with your iphone.. helpful to quickly add changes/new records to your iphone. But the vCard method outlined above is easiest]
Dec 22, 2008 | Apple iPhone 3G
Jun 01, 2007 | Intel Motherboard
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
