Question about Panasonic KX-FPG378 Fax
Have replaced film and unit keeps saying "cover open" or check film. I replaced film correctly twenty times.
  • 28 Answers
On some units it is possible to install the film upside down( backwards) but since you've done it multiple times it is more likely that the sensor that sees the film is broken or blocked. Look for a small block with two little lenses. They don't usually break per se but can get blocked by debris like scraps of paper.
Good luck
Posted on Jul 29, 2009
Just bought Topfield TRF2100, screen on and says"installation", but remote won't work.
Be sure there are fresh batteries in the remote. Be sure they are installed correctly and that there is nothing covering the remote's battery contacts. Look to see if there is a film covering the remote's infrared lens or the receiving unit's eye. Check your manual to see if you need to program the remote to the unit. if it's a multi-unit remote, be sure that you have set it to control the specific unit you're working with.
Jul 17, 2015 | Televison & Video
Error code e007 on canon imagerunner 210s
that is code for damaged fixing film u will need a technician to replace the fixing film. or replace fixing unit( for that, open the front cover; open screw of down left side small cover, remove cover; detach connection on the upper left side.remove earthing screws and in the upper centre, fixing unit mounting screw. release feeder leaver oin right side.open left door, slide out fixing unit replace with a new one and revert whole process.)
Feb 07, 2011 | Canon imageRUNNER 210S Copier
What is Error Code 5100 please
I asked around and this error ..its also instruct you to turn off and on the printer ..it is a warning for an obstruction in the printing process ...most of the times the obstruction having mechanical origins..So look around for sliding parts and in general parts that suppose to move in a certain pattern and now are blocked or not well lubricated or something is blocking them ..
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
FILM ON GLASSES, IS THIS HARD WATER, MIGHT BE MY WATER SOFTENER??
Film on the glasses may be a sign that the softener is not working correctly. It may sound silly but check the obvious first, is there salt in the softener brine tank? if not fill it up, allow it to sit for at least 8 hours then manually regenerate the unit. Also check the power to the softener. Check to make sure the bypass is not open. If this stuff is ok then have a local reputable water treatment company come out and test the water hardness to make sure the softener is working correctly. If they say it is not working check the brine draw tubing. The most common failure is from a slight leak in the brine draw tubing which keeps the unit from regenerating effectively. During the brine draw phase of regeneration (2nd step) the softener should draw all the water from the brine tank. Repair or replace the tubing as needed.
Mar 10, 2010 | Whirlpool 24 in. GU980SCG Built-in...
The printer display an error message E007, the printer model is CANON IR 2016i
The error E007, is a common error for digital copiers, B&W segment.It means that fixing film on fixing heater is worn out.To be exact: on left side of fixing film on heater is little white square.With help of this square, photo sensor knows the condition of fixing film.If this square is "eaten", the sensor does not recognize it and automatically reports error code E007.
Your next step should be to replace fixing film. For EU region, or 230V and 50Hz current, the part number is FM2-3353 FIXING FILM ASSY.
In case of mild worn fixing film, you can try to turn off and on the copier, and get few more copies.
If the copier has over than 500 000 copies, the best solution would be to replace the whole fixing unit.
For EU region, the part number is FM2-3352.
The condition of fixing film you can check with pocket mirror and flash light.
Open the left door, above the drum unit (long green roller) is fixing unit which have warning heat lable.Place the pocket mirror under left side of fixing unit, and you should be able to see the damadged fixing film.Also if the fixing is so badly eaten, on left door should be particles of light brown color.
But however, you should replace the fixing film.
Feb 16, 2010 | Canon iR 2016i Black and White Copier
Check Film and Cover Open: KX-FPC95
Check for slack in film between supply and take-up rollers. Manually advance take-up roller to remove slack before closing cover.
Dec 18, 2009 | Panasonic KX-FPC95 Plain Paper Thermal...
Replaced film, unit say's "Check film, Cover open". Film is fine, cover is closed, can't figure ths out?
I had that problem once and I unplugged it for 5 minutes and then replugged it in and it was fine.
That's what worked for me.
May 30, 2009 | Office Equipment & Supplies
Replaced Drum still says "Replace Drum Soon". How do I reset on a Brother 7420?
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
May 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Panasonic KX-FPG378 Fax Logo
142 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
