Question about Samsung Heating & Cooling
Hi .. i have samsung air condition model ar18hpfsdurx and i turned it on , besides I have to electric source .. when i turn the first electric source off and turn the second electric source on after a while.. this air condition will start to work automatically .... any way to make it off please?
MobyMech
  • 106 Answers
SOURCE: 1987 Toyota Celica overheats when air conditioning is turned on
Hi
The first thing to check is that the engine cooling fan comes on when you turn on the air conditioning, then you should check the condition of the radiator fins. If they are clogged with debris (dead insects, leaves, etc...) then you will need to get a pressure washer onto it through the front grill and try to blast it clear.
When you switch on the aircon, it puts extra stress on the engine, which causes the fuel economy and engine power to drop, and as a result the engine will naturally run hotter, so it needs a bit of help to cool down in the form of the engine cooling fan.
Regards
Geordie
Posted on Jun 09, 2008
keemo68
  • 1263 Answers
SOURCE: air conditioning problem
in most instances when you open an a/c system you must also make sure that it's not only charged properly, but you also have to replace the dryer. moisture in an a/c system is the enemy and when you open the system. the moisture get's in there and plugs the dryer causing a blockage. hence why it only works for a few minutes.
Posted on Aug 28, 2008
  • 19 Answers
SOURCE: 1996 cadillac deville-auto switches to econ when turning on air
i have a 96 DeVille that did the same thing. It means your coolant tank is almost empty. It switches automaticlly to preserve based upon temp readings.
Posted on May 16, 2009
  • 82 Answers
SOURCE: air conditioning switch goes off and on while recirculating air
If I understand correctly the A/C light goes on and off. If so, try to gently push the switch to the side(Not in) while the A/C is on. If this keeps the system working, you need a new control assy(Complete control head)
Posted on Jun 22, 2009
  • 3 Answers
SOURCE: Kia rio air conditioning light?
The manual instructions are basically:
Turn the fan to 0 (off, far left).
Turn the air control to full defrost (far right).
Press the recirculation button at least 5 times within 3 seconds.
If you've done it right, the recirculation button light will flash a few times at about 1/2 second intervals.
I've tried it on mine and this works.
Posted on Jul 08, 2009
My 12000btu spliter air condition start and stop in 5 seconds
24
EN
TROUBLESHOOTING
CAUTION
If any of the following conditions occur, stop the air conditioner immediately, turn off the main power switch and contact the
dealer.
• The indicators flash at short intervals (5 Hz). Reset the circuit breaker 2 to 3 minutes after the power main switch is turned
off.
Despite the resetting operation, the indicators still continue turning on and off.
• The main power fuse often blows, or the circuit breaker is often activated.
• Foreign matter or water has fallen inside the air conditioner.
• Any other unusual conditions are observed.
Before asking for servicing or repairs, check the following points.
Recheck
Inoperative
• The power main switch is turned off.
• The circuit breaker is activated to cut off the power supply.
• The main power fuse has blown.
• The electric current has stopped.
• The batteries in the remote controller used up.
• The ON timer is set.
• As a protective mechanism for the air conditioner, it does not operate for 3 minutes
immediately after restarting operation or turning on the main power.
Poor cooling or heating performance
• The air inlet or outlet of the outdoor unit is blocked.
• Doors or windows are opened.
• The air filter is clogged with dust.
• The louver is not at the correct position.
• The fan speed is set to low.
• The air conditioner is set
to the DRY or SLEEP MODE.
• The temperature setting is too high (during cooling operation).
• The temperature setting is too low (during heating operation). (heat pump models)
Feb 01, 2015 | Samsung AS18A6RB Air Conditioner
My EverStart portable air conditioning unit
sounds like you need to wash your condenser coil. Sounds like your compressor is kicking out on high head pressure. Once it cools off it starts cooling again take it out and give it a bath don't get the electric wet.
Sep 12, 2014 | Heating & Cooling
How to fix central air conditioning
HI.please you check thermostat and electrical fan.
Jul 16, 2014 | Carrier Heating & Cooling
Air conditioning problems
First check that all electrical connections to/from your air conditioning components are tight and secure with no broken or chaffed wires and connectors, or oil swollen connection points. Then check that all fuses and relays involved in the operation of your air conditioning system are operational. If all is good, then remove the belt around the air conditioner compressor pulley. Get a wrench and try to turn the front of the compressor pulley. It should turn with little to no resistance. If it wont move or is very hard to turn, it is probably locked up and needs repair or replacement. If it moves, then the compressor part is OK, but your clutch would likely need replacement. Some model cars its cheaper to just replace the whole compressor than to rebuild the clutch. Jaguar sounds expensive - I would seek out a junk yard. Good luck.
Apr 20, 2014 | 2001 Jaguar S-Type
Samsung Air Conditioner will not turn back on after power Outage
disconnect the units from their power source and wait about an hour. Reconnect to power source and see if this has reset the units.
Hope this helped you good luck on the repairs
Dave
Nov 11, 2009 | Samsung AW1403B Air Conditioner
Code E1 on my Samsung AW1204B Air Conditioner
Found this on Samsungs site.Hope it helps a little, at least you know the problem now.
If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced.
If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced.
To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have the model number of your air conditioner on hand when you call.
Feb 03, 2008 | Samsung AW1203B Air Conditioner
Problem with samsung aw0503b
Found this on Samsungs site.Hope it helps a little, at least you know the problem now. If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced. If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced. To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have the model number of your air conditioner on hand when you call.
Aug 02, 2007 | Samsung AW0503B Air Conditioner
My air conditioner doesn't turn on, what do I look for?
If your room air conditioner doesn't go on at all: 1) Check the power source first: be sure it's plugged in and turned on. 2) Then check the outlet by unplugging the air conditioner and plugging in a light that works (only for standard-voltage models--do not plug a light into a 220/240-volt receptacle!). 3) If the light doesn't go on, the circuit has probably overloaded--check the electric panel or fuse box and reset the breaker or replace the fuse. 4) If the light works, it's likely that the air conditioner's switch is faulty or the thermostat needs adjustment or repair. 5) Be sure the thermostat is set to "cool" and below room temperature. 6) Refer to the manufacturer's instructions for thermostat repair. If adjusting or repairing the thermostat doesn't solve the problem, unplug the unit and call an air conditioning technician.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
