Question about Xerox Phaser 6100/BD Laser Printer
Cleared paper jam, but printer not responding
Hello. I had a paper jam in the fuser area for my xerox workcenter xd 100. I cleared the jam (after much hassle :) and it's still blinking E2. I've closed all the little doors and have even tried turning the power on and off. Please let me know if there is something I'm missing. Thanks!
DG
  • 724 Answers
Did you shut power when removing the jammed paper. If you did not then you have forced the gears against the rotation and may have hurt the transport system
Posted on Jul 27, 2009
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
My Xerox Workcentre copier gives an error message E2 paper jam and I have cleared every possible jam. The copier still thinks its jammed and won't start up now.
I just had this same issue with my phaser3300MFP. Initially I thought this was a software issue but after careful inspection, there indeed was still a jam. I would check the fuser area of the machine. There is most likely a page jammed in that area and they can be hard to see.
Nov 10, 2010 | Xerox WorkCentre XD155DF Laser Printer
XEROX PHASER 6180 SAYS PAPER JAM, I CLEARED PAPER JAM, PUT IN NEW CARTRIDGE, AND IT STILL SAYS PAPER JAM
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Mar 16, 2010 | Xerox Phaser 6180N Laser Printer
Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Clicking sound and crumpled paper
Bad heat roll drive gear in the fuser. Very common problem.
Look up on google a business called "The Parts Drop". Ask for Britt, part is $13 or $14.
Aug 31, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper folds and jams before
your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
ERROR E2
Here is a picture of the aforementioned broken gear, with a replacement gear visible for comparison:
From a different angle:
The printer repairman said that the plastic gear found in this and similar models can fail after as early as a few months of use. Best of luck!
May 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox workcentre xd 100 paper gets jams just before intering fuser
On the XD 100 if it is jamming when it is just entering the fuser, check the gear on the end of the heat roll.
Those frequently crack and or flat out break off.
That gear is easily replaced and inexpensive. If you require information where to purchase one, let me know via a message here.
I checked and you can purchase that gear for $14 or less.
Nov 15, 2007 | Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 6100/BD Laser Printer Logo
172 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
