Question about Microwave Ovens
Oster microwave turntable will not turn, food on one side is hard as a rock
hi suzanne.
If the glass tray in your microwave doesn't turn, it may be due to a broken drive motor. Most units have a round glass turntable which has a motor driven coupler and roller guide turning the tray. To access the motor, first unplug the microwave and remove the bottom panel.
How to Repair a Microwave Tray That Will Not Turn - PartSelect
microwave turntable will not turn Google Search
Nov 07, 2017 | Oster Microwave Ovens
Fix a kenmore microwave turn table model 721.80012401will not turn
Aug 11, 2014 | Kenmore Microwave Ovens
Can you turn down the beep on a Frigidaire microwave
Good Morning Friend,
I understand that you want to turn down the beep on your Frigidaire microwave, model# PLMV169DC. You are not able to turn down the beep, but you are able to turn it completely off. If you wish to have your microwave oven operate with no audible signals, touch Help, the number 2 and Clear/Off. To cancel and restore the audible signal, touch Help, the number 2 and START. Hope this is helpful.
-Best Regards-
Jul 08, 2014 | Frigidaire PLMV169DC Microwave Oven
EW30MO55HS Electrolux 30"microwave doesn't turn or heat
Good Morning Jody, thank you for your post!
If your Electrolux microwave (EW30M055HS) has power but does not heat, often the possibilities include one of four culprits:
·Power Supply
    ·Plugged into GFI Outlet
    ·Faulty Control Panel
    ·Faulty Magnetron
I always recommend resetting your microwave first. You can do so by unplugging your appliance or flipping the circuit breaker for about 30 seconds and then turn your microwave back on. If your microwave stills does not heat or turn, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area.
Feb 19, 2014 | Electrolux EW30MO55HS 30" Built-in Drop...
Microwave will not turn
if you look under the microwave you can usually find an access point to the motor the spins the turn table just needs to be replaced
Nov 29, 2011 | GE Microwave Ovens
Microwave turntable does not turn
In microwave ovens, I have had the turn table motor unit become defective, or the power source to it has failed.
Jerry G.
May 15, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave runs but nothing is hot.
Sounds like the magnatron (the bit that makes the radio waves) has failed.
not economical torepair it,just replaice the whole microwave
Apr 05, 2009 | GE JVM1870 Microwave Oven
Cannot turn off fan
the fan has to stay on,thats the way they are made
Nov 30, 2008 | Kenmore 60654 Microwave Oven
Microwave troubleshooting
I found the fix to the F3H error on another site. Just turn the power to the microwave off for ~2 minutes at the circuit breaker, and then turn it back on. Microwave will start working again then.
Feb 23, 2008 | Whirlpool GH5184XPQ Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
