Question about Cell Phones
How to set alarm day? - Cell Phones
Setting an ultronic touch screen alarm clock
TD00552: 12 hr--military time toggle= tap time set button. Set time= hold down time set button till up & down arrows show on r & l sides; set hour, tap time set button, then set minutes, repeat, seconds, repeat. Date change= tap hour if needed to show day & month; then hold set button on left till up & down buttons show at edges of screen. Up/down buttons to set year on lower right screen, tap set again to change # day of month, tap set again to change month, and the day will correct itself. Change temp c° -- f°= tap alarm button if needed to display temp b them tap set button next to it to change temp scale. Alarm- off/on= tap screen button if needed to show alarm time; tap alarm set button next to it- it will toggle on/off. To set= with alarm time showering, hold down alarm set button till up/down buttons show; follow same process as above.
You are all welcome ??
Jul 01, 2017 | Televison & Video
How do I set the alarm on my alcatel one touch tribe 3000G? I only want it set for one day per week. I can set the time and bring up "once" but the days highlight as 5 or 7 days
I'm afraid the alarm feature only works for weekdays (5) or everyday (7).
But you can use the Calendar and create events at specific dates with "alarm" reminder.
Nov 24, 2014 | Alcatel Cell Phones
How to turn off alarm?
Alarm
Your mobile phone has a built-in alarm clock
with a snooze feature. You can set up to five
separate alarms and choose whether or not
the alarm should repeat.
Setting an Alarm
1. From the main menu, select Alarm.
2. To edit the alarm, press the () key. The
following options display:
• Time: Set the specified time for this
alarm.
• Repeat: Select Once (default)/Every day/
Days or customize as preferred.
• Snooze: The alarm will repeat at regular
intervals.
Jun 15, 2014 | Tracfone Wireless Alcatel A392G
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
Cannot turn off the alarm
The problem appears to have resolved itself. The oly changes I made to the smartphone was to power it off and insert 16GB mini SD memory card. Since powering back up I have not had the alarm warning.
Nov 28, 2008 | HTC S620 Smartphone
Lost instructions for Emerson
to change the alarm mode setting for alarm 1, hold alm1 setting button and press the alarm mode button until the day indicators show thedesired mode setting. weekday only,weekends only,or everday operation. release the alarm mode and alm 1 setting buttons and the display will return to correct time.
Dec 05, 2007 | Emerson CKS2237 Clock Radio
Setting the days on the alarm?
Hold the alarm button down and press the mode button to change the days of the week you want the alarm to go off.
Oct 11, 2007 | Emerson SmartSet CKS1850 Clock Radio
Alarm
The 'mazda' setting is supposed to look like an analog clock, and that's for setting the time. The key position puts the clock in operating mode, as opposed to clock set or alarm set modes.
I've only had the clock for a day, but if you want the alarms to shut off and alarm again the next day, use the OFF switch on the top right of the unit. If you want to disable the alarms completely, use the 1 and 2 buttons behind the OFF switch to cycle each alarm through the settings: none, bell, music (radio)
Sep 06, 2007 | RCA RP5420 Clock Radio
Help setting alarms
To set an alarm for an event: 1. Create a new event or double-click an existing event. 2. In the New/Edit Event dialog box, select the Alarm check box. 3. Click the time interval selector and select Minutes, Hours, or Days. 4. Type a number between 0 and 99 in the Time Measurement box. 5. Click OK. To set a default alarm for all new events: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Date Book tab. 3. Select the Alarm Preset check box. 4. Click the time interval selector and select Minutes, Hours, or Days. 5. Type a number between 0 and 99 in the Time Measurement box. 6. Click OK. Setting Alarm Options You can configure the Alarm Manager settings for the Desktop application in the Alarm tab of the Options dialog box. To set Alarm options: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Alarms tab and click one of the following actions: * Always available: Click this option if you want alarm notifications to appear regardless of whether the Desktop application is running. * Available only when Palm Desktop is running: Click this option if you want alarm notifications to appear only when the Desktop application is running. * Disabled: Click this option if you do not want alarm notifications to appear on your computer. 3. If you want an alarm tone to sound when the alarm notification message appears, click Play audible notification with alarm dialog. 4. Click OK.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
