Question about JBL Audio Players & Recorders
Jbl prx615m has signal but no audio output - JBL Audio Players & Recorders
When they are placed on speaker stands, they lean to one side since all the weight from the components are on one side. Is there a simple way to fix the leaning issue?
Remove one of your shoes. This will cause you to lean slightly and therefore not notice the slanting speakers. It will also improve the quality of your recordings, with deeper bass and a clearer soundstage due to quantum grounding effects.
Dec 29, 2015 | JBL PRX615M 15 Inch Two Way Self Powered...
I need instuction manual for FAL-3 output subconverter
http://www.scosche.com/car-audio/downloads/dl/file/id/667/slc_4_instructions.pdf
The FAI-3A is just the "Walmart exclusive" version of the SLC-4. The two products are identical except for the model number.
Jul 20, 2015 | Scosche Industries Scosche Fai 3a Oem...
My jbl prx615m sounds like it has something vibrating inside the cabinet.
Pay attention to the source of rattling, if its just the enclosure or comes out from the speaker and let me know to improve helping you out...
Aug 27, 2013 | JBL PRX615M 15 Inch Two Way Self Powered...
Prx615m not turn on
Mosfet, FQP27P06/FQP30N60 got fried in the power output stage, this is a common issue with JBL powered by Crown speakers, let me know more to help a bit more also.
Apr 22, 2013 | JBL Bags PRX615M-CVR Cover Speaker
JBL JRX118SP POWERED SUB. Getting power and signal light flashes when theres a signal. Just no sound??? Speaker/coil looks fine..
There's a 8-pin ic located right at the side of output devices & power supply filter caps, that is a common issue with JRX active subwoofers, hope it helps.
Jan 29, 2012 | JBL JRX 115 JRX115 15 JRX118s 118s Speaker...
NO audio output. Unit is on, illuminated, and so on, but no audio output to any of the speakers
what kind of car is this in? there are several reason you can be missing audio
Sep 11, 2010 | JBL MR35 CD Player
Continous low level pulsing but no Base Response from JBL PSW1000
There is a huge discussion among audio enthusiast regarding subwoofer output and how you should connect your sub to your system. If sub preout is turned and on your amp/receiver and you are able to adjust the crossover frequency adjust your crossover frequency to highest setting, higher HZ number, so you don't double low pass filter your signal too much. If you can adjust crossover frequency on your receiver and your sub allows separate connection to by pass it's filter, use that instead.
There is a great article on Polk Audio website regarding Home Theater setup. You can use it as reference and tweak it to your taste.
Aug 18, 2009 | JBL PSW1000 Speaker
Jbl gto 75.4 right channel not working
Hi
It's rare that 2 channels will fail simultaneously, are you sending 4 signals to the amp or just 2?
If you are sending just 2, perhaps the problem lies before the amp in the cabling to it, or the output from the headunit. If you are sending 4 signals then there may be a fuse in the amp that drives 2 channels out of the 4. Of course this may be the case should you just be sending 2 signals.
Dec 25, 2008 | JBL GTO75.4 Car Audio Amplifier
My amp goes out and turns red when i get to a certain volume
get a 1.5 farad they have them at walmart for like 40 bucks
Dec 23, 2008 | JBL BP600.1 Car Audio Amplifier
Car audio amp (?) issue
To me, it sounds like your "Output Devices" in the MAIN Amp have gone faulty. BUT check the OUTPUT directly at the Head Unit & then the Amp's terminals to make sure.. if ya dont have any signal comming out of the "Head Unit" than thats ya fault.. however if that has a good signal out,there, then it's gotta be ya Main Amp. Ya can check to se if there is output with a small speaker with wires on it, or my favorite an modified earphone, with the wires ends exposed so ya can "Touch" them to the Output terminals/Plugs etc, of whatever ya wanna test. NB: Only test at a low level output.
Aug 08, 2007 | Legacy Audio American Legacy II LA290 Car...
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
